84' Corolla charging issue - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla Forum > Older Generations (1969-1987)
Older Generations (1969-1987) Specific discussion of the AE86, along with generations 1 through 5.
Old 05-11-2008, 08:16 PM   #1 (permalink)
raygun's Avatar
View raygun's Photo Gallery
Today I bought a 84' corolla. It had been setting for over a year. I started it up and drove it home, but the charge light remained lit. The PO said it was charging when he parked it. Any ideas on gettinf it to charge? Is it the Alt. or the voltage reg?
raygun is offline   Reply With Quote
Old 05-20-2008, 07:24 PM   #2 (permalink)
EJ86's Avatar
View EJ86's Photo Gallery
AE86
If you left it sitting for a year and didn't start it like your supposed to. Fuel lines could get corroded which leads you w/ more stuff to replace, battery, alternator, fuel lines, etc.
-1985 Toyota Corolla GTS (2dr)
http://www.cardomain.com/ride/561054
EJ86 is offline   Reply With Quote
Old 06-04-2008, 12:01 PM   #3 (permalink)
Toyota Hemi
camryfour's Avatar
View camryfour's Photo Gallery
I would say check all of the fuses, under the dash and under the hood. Also, check the fuseable link on the positive of the battery. Then go test the alternator at your autoparts store. Once everything checks out and it still does not work, then look into changing the voltage regulator. If you changed everything and it still does not charge, you may have a wiring issue.
camryfour is offline   Reply With Quote
