t50 (stock ae86 5 spd) bolts right up since all 4age (or A series for that matter) blocks use the same housing pattern.
the dizzy cap is on the trans side of the head, so it will not clear the firewall, which is what theyre talking about. theres really two ways to get around it, bang the shit out of the firewall (or cut a hole in it, and weld in a new section around the cap), or get a distributor relocation kit, which will position in with the cam gears. obviously the second one is much nicer, but it isn't cheap.
but yes, you could go with a standalone setup, and eliminate the dizzy completely. usually this is done by using a Ford EDIS4 ignition system controlled by MS.
the water lines exit on the trans side of the head as well, so those obviously must be modified. once again, the nicer option would the the SS kit which has billet housings and such. but alot of people just have theyre own inlets and outlets and pipes welded up and will work just as well.
and yes, its important to know what engine you have in the car (bluetop 4A-GE or 4A-C). basically, with the SR-5/4A-C you'll have to factor in the fact that your converting the car to EFI. you'll need to wire up a fuel pump relay circuit, and convert your actual fuel system over. the 4A-C uses a mechanical, low pressure fuel pump mounted on the head. you'll need to get an electric fuel pump. easiest thing would be to get a GT-S tank, pump, and sending unit and throw it on. you could go with an external/in-line pump and keep your existing tank. however im not sure with the 86's, but they probably don't have any baffling in the SR-5 tanks, which means, you could starve your pump on hard cornering (this could be solved by adding a surge tank).
biggest thing, RESEARCH! take a look at club4ag.com, it's a pretty popular swap.
