An sr5 to a GT-S - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla Forum > Older Generations (1969-1987)
Older Generations (1969-1987) Specific discussion of the AE86, along with generations 1 through 5.
Old 07-13-2008, 08:02 PM   #1 (permalink)
View Oricalcos123's Photo Gallery
An sr5 to a GT-S
There a guy in my building that has an 85/86 corolla sr-5 and i want to change it into a gt-s but i wana fit a 20v blacktop into it. was wundering if ne one knows how hard it would be and if they could gime ne pointers??
thanks
Oricalcos123 is offline   Reply With Quote
Old 07-13-2008, 10:22 PM   #2 (permalink)
Wonderbread
4agetercel's Avatar
Gameroom cash: $160040
View 4agetercel's Photo Gallery
AE86
Tons of work and part hunting, How Hard? depends how mechanically inclinded you are
4agetercel is offline   Reply With Quote
Old 07-14-2008, 07:36 PM   #3 (permalink)
i had found a place that sells the motor, ecu, wiring harness power steering pump, injec rails, there a 5 speed tranny but it prob a FWD just wasnt too sure if a AE86 trans would bolt to it or would i have to use 1 from a dif car
Old 07-14-2008, 10:15 PM   #4 (permalink)
Wonderbread
4agetercel's Avatar
AE86
well are you keeping the transmission thats in your car now?
Old 07-14-2008, 11:27 PM   #5 (permalink)
on full afterburner
Gameroom cash: $1344797
club4ag would be a better place to ask this
Old 07-15-2008, 09:13 PM   #6 (permalink)
the only think is that the trans in it now is an automatic and i want it to be standard, be so much better that way.
Old 07-15-2008, 10:23 PM   #7 (permalink)
Wonderbread
4agetercel's Avatar
AE86
Well buddy heres a quick run-down, for a GTS swap you need:
GTS Rear-end
GTS driveshaft
GTS transmission (T50)
GTS flywheel and clutch
GTS gas tank and lines
5spd pedals, master cyliner, lines, slave cylinder
for a AE111 4AG 20V you need to either bash the firewall with a hammer or cut it
water line re-routing (there is kits to buy or you can check club 4ag and it shows you what to do for a RWD 4AG water pump)
Cut out the shifter hole(automatic hole doesnt line up)
WIRING............ plus whatever i havent mentioned(im sure ive missing something)
As for putting it in, it all bolts in the original mounts
Old 07-15-2008, 11:56 PM   #8 (permalink)
operation boro thunder
View project trueno's Photo Gallery
thanks
First thing: Get the guy's permission before you touch his car?
j/k
The gearbox attached to the 20V WILL be a FWD transaxle. Since you need to source a T-50 transmission (bolts right up to the 20V 4AG), and the car being an SR5, might as well source a GT-S donor car.
No you do not NEED to bash the firewall or cut it, since there are distributor relocation kits available. Waterline plumbing kits are out there as well.
project trueno is offline   Reply With Quote
Old 07-16-2008, 05:45 PM   #9 (permalink)
Wonderbread
4agetercel's Avatar
AE86
Well yeah there are other alternatives, expensive ones, its like 600 for the dizzy re-locator and i cant remember how much the water line kit is but its not cheap, i gave the cheap alternative
Old 07-16-2008, 05:53 PM   #10 (permalink)
sweet thanks for the info, it going 2 be a little of a project car just something to do in the spare time but at the same time i want to do it good and there is a place called Curco by Toronto that u can buy a LSD so the rear can be covered lol. just would have to see how much they are, too much just weld the ring and spyders on a GT-S, the redneck way.
Old 07-16-2008, 06:56 PM   #11 (permalink)
Wonderbread
4agetercel's Avatar
AE86
unless the car is gunna go down a straight line all the time or is a feild car i wouldnt do it
Old 07-16-2008, 09:10 PM   #12 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $272921
View REN69's Photo Gallery
LSD in Toronto you're problaby paying about $15 a hit.... oh wait, wrong LSD... I'd say around $1500 for a good one.
REN69 is online now   Reply With Quote
Old 07-20-2008, 09:31 AM   #13 (permalink)
could do a 1.5 LSD so it dont completely lock up around corners
Old 07-20-2008, 12:48 PM   #14 (permalink)
Wonderbread
4agetercel's Avatar
4th Generation
well i think a 1.5 LSD is locked up during acceleration and decelleration, just no lock up in reverse, so going around turns you will be locked up
