need help with idle problem on 85 SR5
hi, i have a 85 SR5
just got it a couple of weeks ago... trying to get it run straight for now before i get my swap...
long story short....
i'm having some idle problem when i start up my car...
it idles from 500-800 rpm... and sometimes it will drop as low and 400's and die out...
i tried some carburetor cleaner spray, cleaned it out... and it's still doing the same...
i also sprayed it on my vacume hose to see if there was any leaks, then i sprayed it on the hose that is below the airfilter, next and infront of the carberator, then my rpm's went up while i sprayed it there, so i thought it was that hose, i replaced it, but still doing the same...
has anybody experienced this problem??? any solutions???
i also want to rebuild my carberator, but don't have any instructions, or guide, and never done it before... anybody know any good sites with diagram for it???
thank you ^^
