detent cable - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla Forum > Older Generations (1969-1987)
Older Generations (1969-1987) Specific discussion of the AE86, along with generations 1 through 5.
Old 08-12-2008, 07:43 PM   #1 (permalink)
View andyp762's Photo Gallery
detent cable
I just the my a40 3 spd trans rebuilt. The car runs strong with it but it's delayed int shifting into 3 rd gear. I've adjusted the cable but it may be stretched since my rebuilder did not repalace it or My measurements with the throttle open are off. I do not know how much it is supposed to be. Any ideas?
andyp762 is offline   Reply With Quote
Old 08-14-2008, 01:58 PM   #2 (permalink)
Doctor J's Avatar
Gameroom cash: $262390
View Doctor J's Photo Gallery
Verify that throttle opens all the way, adjust bell-crank if needed;
if probem pesist test -drive the car with disconnected kick-down cable[the shifts can be to early but the point is to make sure you have 2-3 shift.]
If still not shifted the rebuilder messed up the sealing rings on direct clutch hub[this will also cause slipping REVERSE}
Doctor J is offline   Reply With Quote
