Where is Charcoal canister? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla Forum > Older Generations (1969-1987)
Older Generations (1969-1987) Specific discussion of the AE86, along with generations 1 through 5.
Old 09-19-2008, 07:10 PM   #1 (permalink)
View Bear62's Photo Gallery
Question Where is Charcoal canister?
Hi all. I own an '87 AE82 Seca 4A engine (Australian spec) and am having fuel supply problems when the engine is hot. Replaced filter and pump but fuel is still not sucking from the tank. Someone suggested it may be the charcoal canister/vacuum problem. Is the Charcoal canister the long brass tube behind the passenger rear wheel near the fuel cap? This tube has 3 lines to it coming from the tank.
Thanks
Bear
Bear62 is offline   Reply With Quote
Old 10-05-2008, 12:43 PM   #2 (permalink)
TN User
View TheInjun's Photo Gallery
I have an 1985 Corolla SE 1.6 2BL and mine is right next to the air filter/carburetor and such... but I'm having a problem... Toyota no longer sells them... anyone know where i can pick a replacement up? I kinda need it because it failed emissions due to high CO2 lol.
TheInjun is offline   Reply With Quote
Old 10-05-2008, 01:01 PM   #3 (permalink)
TN User
hmmm I was told by a couple of junkyards that they cannot sell it used because its an emissions part.
Old 10-05-2008, 01:23 PM   #4 (permalink)
just a nobody
The charcoal canister is for the fuel vapor from the fuel tank, it doesn't really controls the exhaust emission of the engine. You might have other concern with the engine that is causing high CO reading; like spark plugs or timing problems.
N.E.O.
Old 10-05-2008, 09:54 PM   #5 (permalink)
TN User
N.E.O.
ok well im going to replace the O2 sensor... But the charcoal canister still needs to be replaced or rebuilt... can anyone help with that? or know a place that specializes in older import parts?
