4AC Valve cover torque specs - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla Forum > Older Generations (1969-1987)
Older Generations (1969-1987) Specific discussion of the AE86, along with generations 1 through 5.
Old 09-27-2008, 08:39 PM   #1 (permalink)
View grubbslinger's Photo Gallery
Great looking forum! I'm trying to find the torque specs for a 4AC valve cover. I bought a Toyota factory manual and can't find it.
Thanks
Rob
grubbslinger is offline   Reply With Quote
Old 10-09-2008, 10:42 AM   #2 (permalink)
View HACI_corolla's Photo Gallery
i don't think it matters too much, it's just the valve cover as long as it doesn't leak and you don't brake it
HACI_corolla is offline   Reply With Quote
Old 10-09-2008, 10:43 AM   #3 (permalink)
what does your toyota factory manual say about headbolts? does it say discard and use new ones?
Old 10-09-2008, 11:01 AM   #4 (permalink)
Thanks for the reply. I cracked my initial valve cover by overtightening. I purchased another at a wrecking yard. Cleaned/installed. Started off at 10 ft/lbs, worked up to currently 13 ft/lbs. around two weeks w/ no leaks
Old 10-09-2008, 11:07 AM   #5 (permalink)
they're really flimsy to be honest. i am putting a new head gasket and I am trying to figure out if the head bolts are one time use or not, does your factory manual say anything to enlighten me?
Old 10-09-2008, 04:06 PM   #6 (permalink)
No. When it comes to the valve cover the shop manual isn't very helpful. The information may be in there but I'm not finding it easy to find. I re-use the nuts but replace the gasket and the gasketed washer,
