3S-GTE swap in an AE86 - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla Forum > Older Generations (1969-1987)
Older Generations (1969-1987) Specific discussion of the AE86, along with generations 1 through 5.
Old 10-08-2008, 11:47 AM   #1 (permalink)
HIT
View HIT's Photo Gallery
hey everyone, i was lookin up stuff on possible swaps in the 86 and the 3s-gte popped up. i have a few questions and for starters,
1) the tranny made for this motor.. is it fwd, rwd or awd?
and
2) the 3s-ge (non turbo) is that an fwd, rwd or awd?
any help would be appriciated.. thankx!
HIT is offline   Reply With Quote
Old 10-08-2008, 09:53 PM   #2 (permalink)
Wonderbread
4agetercel's Avatar
Gameroom cash: $160040
View 4agetercel's Photo Gallery
AE86
1.Altezza trans or a W5x with a custom bellhousing
2. 3sge is fwd engine in the 86-89 celicas GTS and there is a RWD 3sge beams engine from a JDM Altezza
There is a red top and black top versions to the JDM 3sge, black top is Altezza and red top was in 95+ JDM MR2's,
It is not a simple swap by any means
4agetercel is offline   Reply With Quote
Old 10-08-2008, 10:59 PM   #3 (permalink)
HIT
3sge beams!! thankx for bein specific man! this actually helped a lot but umm i was wondering abt a few things. like for instance..
1) the 3sgte, is that awd, fwd or rwd?
and..
2) when u say altezza tranny, since im in canada, could i use the is200, is300 tranny? or any 'IS' model tranny for that matter?
thankx soo much again man!
Old 10-08-2008, 11:03 PM   #4 (permalink)
HIT
3S-GE into AE86???
Old 10-08-2008, 11:05 PM   #5 (permalink)
HIT
also, does the motor support a 5speed tranny or 6 speed tranny??
Old 10-10-2008, 11:30 AM   #6 (permalink)
Wonderbread
4agetercel's Avatar
AE86
3sgte is in alltrac(or GT4) celicas, and theyre in JDM calidinas, also GT4, IS200... ive never seem one here thats why i said Altezza, IS300 has a W55 in it I think or a W58 which I said in my previous post that you need a custom bellhousing for, Altezza trans that are with the 3SGE BEAMS are 6speeds but im not sure which trans it actually is as far as model...
Old 10-13-2008, 10:55 AM   #7 (permalink)
HIT
ohh okay, soo te turbo 3sge is all wheel huh.. so does that mean that if the swap was done, the 86 would be awd? that would suck.. and umm
2) the red top beams edition (3sge) the one of the '95+ JDM MR2's' is that rwd and 5speed??
Old 10-13-2008, 10:57 AM   #8 (permalink)
HIT
cause like pretty much if this helps, i wants a rwd motor and tranny and i jus need to know which one would u recommend of the 3sge or 3sgte or beams edition that is rwd?? thankx man!
Old 10-13-2008, 11:39 AM   #9 (permalink)
View EverAE's Photo Gallery
no the only thing that makes it a certain drivetrain layout, is the transaxle/transmission, the engine can be bolted into whatever layout you want, only things that will need changing is plumbing and such.
you can get an 3sgte and bolt on the altezza rs200 6speed, or the is200, or get a custom bellhousing and run whatever you want.
EverAE is offline   Reply With Quote
Old 10-13-2008, 01:52 PM   #10 (permalink)
Wonderbread
4agetercel's Avatar
AE86
^^ did you read what i said here?? Altezza trans or W5x with custom bellhousing, Wseries transmissons were available in supras which are RWD, i wasnt giving you advice on putting an alltrac setup in it, even though an MR2 is rear wheel its still a front wheel setup because the engine is in the back, but if you take say a Altezza trans and bolt the 3sge to it and its good to go for an AE86, then you have to make up some mounts for the trans and engine, then an upgraded rear end from a MK1 supra which needs to be modded to fit the AE86, upgraded fuel system, not to mention all the wiring mess that has to be dealt with, re-plumb all the waterhosing amoung other things, and if you get a JDM engine parts wont be easy to find or cheap especially for a BEAMS engine, which will run you around 2800-3400 just for the engine and trans itself,
Old 10-14-2008, 07:38 AM   #11 (permalink)
HIT
hmm.. yeaaa lotta mods needed eh! but umm stupid question, speaking of the beams motors (red and black top) i could use either motors with either transmissions rite? the reason im asking this is because earlier in this post i was specific abt the red top but if i could jus buy a black top off an altezza along with its 6 speed tranny then that would solve a lotta problems rite? and make my life a slight bit easier? and by problems i meant getting a w5x tranny with custom bellhousing..
Old 10-14-2008, 07:57 AM   #12 (permalink)
HIT
also, after lookin up some stuff, if the 86 can use the black top i found this swap package which includes the following
  1. COMPLETE BLOCK & HEAD
  2. 6 speed TRANSMISSION
  3. 5Zigen Exhaust Manifold
  4. ECU (Computer)
  5. Complete Wiring Harness
  6. INTAKE MANIFOLD
  7. ALTERNATOR
  8. INJECTORS
  9. FUEL RAIL
10.SENSORS
11.Throttle Body
12.POWER STEERING PUMP
13.A/C Compressor
what im wondering is, can i replace all the exact ae86 parts with the ones i mentioned above so that they are all new or is that not possible for whatever reason?? thankx!
Old 10-14-2008, 10:24 AM   #13 (permalink)
  4. ECU (Computer)
  6. INTAKE MANIFOLD
  7. ALTERNATOR
  8. INJECTORS
  9. FUEL RAIL
10.SENSORS
11.Throttle Body
13.A/C Compressor
not really sure what your getting at...you HAVE to use all those parts on your swap, you dont use any of that stuff from your 86, you use beams hardware on a beams engine.
Old 10-14-2008, 11:39 AM   #14 (permalink)
Wonderbread
4agetercel's Avatar
AE86
you could gut the A/C compressor and powersteering, it will take alot of work to modd the lines to make it work, unless you abosolutly cant live without either, and you will have a bit less lag on the engine better on gas a and more responsive, thats just a generic description of what the engine has, youll find out everything you need once you get down and do it, and the blacktop is a full RWD setup so it will be the easiest to plumb and stuff like that
Old 10-14-2008, 10:07 PM   #15 (permalink)
HIT
ohhh okay!! i get it now! soo i pretty much need the above for the swap. so buyin the engine and tranny itself is pretty much useless. kk and yeaa ive decided to go for the black top beams swap cause thats prob the least of the problems lol now only if i knew a shop in toronto that would have enough knowledge and the resources to do a clean swap!! =(
