starter problems - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla Forum > Older Generations (1969-1987)
Older Generations (1969-1987) Specific discussion of the AE86, along with generations 1 through 5.
Old 12-04-2008, 01:19 PM   #1 (permalink)
View sweet79's Photo Gallery
USA starter problems
Hey guys, does the 86 corolla have a starter relay or ignition relay that gets stuck when its cold. My car won't crank when its cold. I can hook it up directly to the battery and start the car that way, but that sucks on cold mornings. How and where is the wiring from the key to the starter. It is an auto so the neutral start switch could be a problem but it doesn't crank in neutral either. Thanks guys
sweet79 is offline   Reply With Quote
Old 12-08-2008, 12:07 PM   #2 (permalink)
View HACI_corolla's Photo Gallery
did you check the fuses? relays?, under the hood there is a black box, check in there
HACI_corolla is offline   Reply With Quote
