4AGE Timing Gear on the crank - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla Forum > Older Generations (1969-1987)
Older Generations (1969-1987) Specific discussion of the AE86, along with generations 1 through 5.
Old 12-12-2008, 12:21 AM   #1 (permalink)
Ae86ByN's Avatar
View Ae86ByN's Photo Gallery
AE86 4AGE Timing Gear on the crank
Is this thing pressed on? Or is mine just rusted that bad? Because I do not have a manual to find out. Please help!!
Ae86ByN is offline   Reply With Quote
Old 12-12-2008, 01:14 PM   #2 (permalink)
Wonderbread
4agetercel's Avatar
Gameroom cash: $160040
View 4agetercel's Photo Gallery
the timing belt sprocket should just slide off the crank, none of them are pressed on
4agetercel is offline   Reply With Quote
Old 12-12-2008, 02:30 PM   #3 (permalink)
Gameroom cash: $133855
they are not pressed on, however it is very common (especially ae86's with them facing forwards) for these to pretty much weld themselves on with rust.....
The one I just pulled on my ae86 I ended up actually breaking the oil pump attempting to get off (that was after I broke my puller getting the crank pulley off)..... I also destroyed the gear itself, so make sure you have spare parts.
Old 12-13-2008, 08:45 PM   #4 (permalink)
Ae86ByN's Avatar
AE86 oh ya
by the way i sold the 3sge
and bought a 4age for $200
Old 01-04-2009, 05:51 PM   #5 (permalink)
View dwebb99's Photo Gallery
do a search on Mr2OC club web site(4age). Plenty of tricks to getting that little sucker off, worse case....chisel it off...new ones cost $25 from dealer.
dwebb99 is offline   Reply With Quote
Old 01-08-2009, 07:45 PM   #6 (permalink)
noadvertisingplease.com
View Brian's Photo Gallery
If you know how to use a tap to thread holes, you can carefully drill 2 holes and tap them to m6x1.0 then use a bolt-grip puller (steering wheel puller or duckfoot style) to remove the sprocket.
Easy to do on a FWD or MR2 but on the ae86 it's best to remove the radiator to make a bit more space.
Brian is offline   Reply With Quote
Old 01-09-2009, 11:09 AM   #7 (permalink)
Wonderbread
4agetercel's Avatar
if you havent gotten theis off yet, listen to brian he is wise
Old 01-16-2009, 04:04 PM   #8 (permalink)
Ae86ByN's Avatar
AE86 yup, still doing the hard part
ya i got the gear off but im still cleaning the dam thing. Its a (machine shop) engine so im cleaning it before i take it in. Ive also been kinda working a lot and the car im driving now is about to give soon so im trying to get this done as fast as 1 or 2 people can. Im going to start cleaning the head soon, any tips on that???
