puts flame suit on---preignition or detonation during initial throttle transitions from idle position will cause lots of damage.
from my very limited knowledge, i would think that doing some kind of alterations to the distributor will change the degree's allowed from 0 to 25 degrees. (change some of the components in there around? i have no clue what? springs? levers? gears? cogs? thicker wire? more current?)
edit:
When accelerating, there is a place where letting off a bit on the gas seems to give me move power than holding position or applying more gas. I don’t know if this is related to the timing or not.
Thanks for any help.
Mark
I think this has to do with a Rich environment, especially if you have part damage. does the engine smoke alot? Also the power band could have been affected as parts wear over time. this might not be noticeable in a heavier/clunkier/more common coupe, but in the hachi-back i can notice shifts in power band due to small changes in engine wear etc.
