Rear Diff ID - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla Forum > Older Generations (1969-1987)
Older Generations (1969-1987) Specific discussion of the AE86, along with generations 1 through 5.
Old 12-21-2008, 05:13 AM   #1 (permalink)
Levin Driver
Shinigami's Avatar
View Shinigami's Photo Gallery
Rear Diff ID
Hi all,
I was wondering if there is an EASY way to find out if I have an LSD?
I just bought an '83 Levin GT, and I'm trying to take stock of what I have before I drop any cash on improvements. LSD is on the top of my wish list, but I'd feel like an idiot if I bought one, reserved the lift at work, and then pull out a perfectly good LSD!
I only have very basic tools. When I want to do actual work I have to call in a favor from a friend.
Ideas?
Cheers
Shinigami is offline   Reply With Quote
Old 12-24-2008, 10:16 AM   #2 (permalink)
KoniProthaneCuscoTanabe
View nbm077's Photo Gallery
AE86
start by taking the rear axel housing off
looking for an AE86?
http://calgary.kijiji.ca/c-cars-vehi...QAdIdZ90208390
nbm077 is offline   Reply With Quote
Old 12-24-2008, 10:21 AM   #3 (permalink)
AE86
Just jack up the rear of the car, spin one tire by hand and if the other tire turns in the same direction, you have LSD... or welded gears
to see if it is welded, have some one hold the other side and turn it in the opposite direction it's a little hard, but if it moves that means it's not welded and you got LSD
Old 12-24-2008, 07:02 PM   #4 (permalink)
Levin Driver
Shinigami's Avatar
Thanks, that's the kind of solution I was hoping for. I'll have it up on a lift this weekend! I'm pretty sure it doesn't have one, but I want to make sure.
Cheers
Old 12-25-2008, 12:07 AM   #5 (permalink)
View datsa's Photo Gallery
So, a limited slip differential means that when I turn one tire forward, and the other tire (on the opposite end of the axle) turns in the forward direction (when it is not being held)? Or is it supposed to move in the backward direction?
datsa is offline   Reply With Quote
Old 12-25-2008, 02:22 AM   #6 (permalink)
the diff works on torque differences on these cars. it has to do with angular momentum and the dynamics of rotational bodies.
c/p
A differential is a device, usually but not necessarily employing gears, capable of transmitting torque and rotation through three shafts, almost always used in one of two ways. In one way, it receives one input and provides two outputs; this is found in most automobiles. In the other way, it combines two inputs to create an output that is the sum, difference, or average, of the inputs.
In an automobile and other wheeled vehicles, the differential allows each of the driving wheels to rotate at different speeds, while supplying equal torque to each of them. In automotive applications, the differential and its housing are sometimes collectively called a "pumpkin" (because the housing resembles a pumpkin).
vehicle's wheels rotate at different speeds, especially when turning corners. The differential is designed to drive a pair of wheels with equal force, while allowing them to rotate at different speeds. In vehicles without a differential, such as karts, both driving wheels are forced to rotate at the same speed, usually on a common axle driven by a simple chain-drive mechanism. When cornering, the inner wheel travels a shorter distance than the outer wheel, resulting in the inner wheel spinning and/or the outer wheel dragging. This results in difficult and unpredictable handling, damage to tires and roads, and strain on (or possible failure of) the entire drive train.
diffs have been around since the train days in mechanical vehicles. just like leaf springs
lsds are for better traction
basically its the slip in the tire that causes the massive torque which must select lsd clutch plates etc ordered placed correctly in the lsd.
2nd year mech stuff.
http://www.mcasco.com/p1rdy.html
Old 12-27-2008, 08:06 AM   #7 (permalink)
Levin Driver
Shinigami's Avatar
Just had the car up today. Turning one wheel, the other one turned in the opposite direction, meaning NO LSD.
The good news is the car got the seal of approval from the AE86 shop/garage, so it looks like I got a good deal!
Cheers
