What's that part? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla Forum > Older Generations (1969-1987)
Older Generations (1969-1987) Specific discussion of the AE86, along with generations 1 through 5.
Old 12-22-2008, 04:10 PM   #1 (permalink)
View Mark57's Photo Gallery
What's that part?
1986 Corolla 4AC Auto 2bbl
Located behind the glove box and attached to the heater core box is a component with a 12 pin connector going to it. On top is an adjustment knob with corresponding markings of H...........RPM............L. Anyone have an idea about what this adjusts the speed on? Tore my Haynes apart looking for it - no luck.
Thanks, Mark
Mark57 is offline   Reply With Quote
Old 12-28-2008, 03:13 PM   #2 (permalink)
View uraverageyota's Photo Gallery
its called an ac amplifier, dooes your ac compressor have a revolution sensor mounted on the rear of it? Should be a 2 pin conector if it does. The amplifier can be adjusted to keep the compressor clutch engaged a bit longer or less. But the 4A/C motor should have a 10 pin connector with only 9 pins being used. 4A/GE motor 14 pin connector w/13 pins being used.
uraverageyota is offline   Reply With Quote
