fx16 w/4age front bearing replace?? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla Forum > Older Generations (1969-1987)
Older Generations (1969-1987) Specific discussion of the AE86, along with generations 1 through 5.
Old 01-11-2009, 08:30 PM   #1 (permalink)
View Comrade_charlie's Photo Gallery
My fx16 1987 with the 4age needs a bearing. Where should I get one and how much do they usually cost
What all needs to be done to replace it? Ive replaced bearings in my 300zx but its not fwd.
Is the bearing just one unit, or does it have an outer and inner?
Comrade_charlie is offline   Reply With Quote
Old 01-11-2009, 08:41 PM   #2 (permalink)
noadvertisingplease.com
View Brian's Photo Gallery
Wheel bearings require a press to install, and a way to undo and re-torque the 30mm axle nut.
The easiest way might be to take the knuckle off and drop it at a machine shop and have them r&r the bearing for you.
- Brian
Brian is offline   Reply With Quote
Old 01-12-2009, 11:32 AM   #3 (permalink)
Ok, my friend has a press, and my other friend has a shop. I might drop it off at the shop, take out the axle nut and then take the whole assembly to my friends house with the press....
can you use a vice to press it in, or does it need to be a press?
Thanks
Old 01-12-2009, 08:30 PM   #4 (permalink)
Originally Posted by Brian View Post
Wheel bearings require a press to install.
They also require a press and some know-how to remove from the knuckle.
- Brian
Old 01-12-2009, 10:42 PM   #5 (permalink)
The wheel has no play in it, it just makes TONS of noise. I dont have money to get a shop to replace it, so I have to do it myself or get help from my friends.
My buddy owns a shop and does a lot of work like this, just maintinece work, im waiting on what he thinks about doing it at his shop.
Thanks
Old 01-13-2009, 01:04 AM   #6 (permalink)
Tire noise is often confused with bearing noise, so first things first, you might want to do a front-rear tire rotation and make sure the noise doesn't move to the back.
Then change the bearing
- Brian
Old 01-13-2009, 12:00 PM   #7 (permalink)
they are cheap new tires(prime wells?)
but at first I thought it was the tires, if you drive it, you cant hear that its just from the front left, it sounds like all 4. but i rode in the back passenger seat and it only comes from that one tire area... i will try rotating themm sometime soon.
Thanks
Old 01-15-2009, 01:07 PM   #8 (permalink)
rollagtsracer's Avatar
View rollagtsracer's Photo Gallery
i just replaced my wheelbearings the bearing at my local parts store was like 27 dollars i have an fx16 gts they told me they couldnt get the bearings off so i had to buy new hubs
to 4age or not to 4age
rollagtsracer is offline   Reply With Quote
Old 01-15-2009, 01:14 PM   #9 (permalink)
How much was that?
Old 01-15-2009, 01:31 PM   #10 (permalink)
i got my hubs from a junkyard i used ones from a 91 corolla 4 door they work for now if you find fx16 hubs you r a miracle worker i searched for three weeks
Old 01-15-2009, 05:39 PM   #11 (permalink)
there is an 87 fx16 with the other motor the sohc tbi one or carb one at my junkyard... but would those hubs work? should I pick them up?
Old 01-15-2009, 09:08 PM   #12 (permalink)
You can ALWAYS get the bearings off the hubs. It just takes a grinder with a zip disc. Put the hub in a vise. Notch the inner race (without nicking the hub) and then hit it with a big hammer and chisel.
- Brian
Old 01-18-2009, 11:11 PM   #13 (permalink)
Thanks for the information
But Id still like to know if the hubs from the fx16 with the sohc wil work?? If so ill buy them if I need them, or just throw them on ebay.
