i didn't know much about transmission, but one thing I want to point out is if you swap an a40d in your 1983 I think you need more than a bell housing (bell housing is difference between 1983 3tc with a40d and 1983 4ac with a41) since a40d is electronically control. as far as I can think of now, your gear shifter need to be change since a40d is come with overdrive but an a41 gear shifter didn't have the od switch. also I think the drive shaft may not fit since they have different parts number.
83 Corolla s/w
01 Prius
