4A-C Clutch - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla Forum > Older Generations (1969-1987)
Older Generations (1969-1987) Specific discussion of the AE86, along with generations 1 through 5.
Old 02-08-2009, 04:19 PM   #1 (permalink)
View fredricktflail's Photo Gallery
4A-C Clutch
Is the ae82 4ac clutch the same as the ae86 4ac clutch?
fredricktflail is offline   Reply With Quote
Old 02-10-2009, 07:34 PM   #2 (permalink)
I kick ass, I make bail.
View Punkrampant's Photo Gallery
Re: 4A-C Clutch
The clutch disk on both is the same part number, the pressure plate is not.
Punkrampant is offline   Reply With Quote
Old 02-11-2009, 08:57 AM   #3 (permalink)
View AA01's Photo Gallery
4A Clutches
The 4ac clutch for both should be interchangable,for that matter any 4AC or 4AGE clutch will fit your car, as long as it is a 200mm disc and pressure plate. So an AE86 4AGE or 4AC clutch will work. (the only difference i could see is that it will grab a little better) The FX-16 4AGE and 4AC clutches will work as well. The only MR2 (AW11) clutch that will not work is the 212mm clutch, as it uses a different flywheel. The MR2 200mm clutch will work just fine as well.
AA01 is offline   Reply With Quote
Old 02-24-2009, 09:48 PM   #4 (permalink)
Does anybody else know if the the two clutches are the same or fit and work, I just was wondering i dont want to buy a differnt one and have it not work, thanks
Old 02-24-2009, 09:54 PM   #5 (permalink)
I thought I gave an adaquite answer with....well....the list of what fits and what doesnt.....but if you need a clearer answer....YES IT WILL FIT.
I have personally tried all these combinations without issues.
Old 02-24-2009, 11:02 PM   #6 (permalink)
I was just looking for a second option. Do you know if the throwout bearing is he same too?
Old 02-25-2009, 07:00 AM   #7 (permalink)
Yes the throwout bearing should be the same as well.
The reason these parts are interchangeable is that these are both 50 series trannys (the fwd being the C50 and the rwd being the T50).
Old 02-25-2009, 09:21 AM   #8 (permalink)
well im gonna try it out as soon as I pick a cluch out. You guys might think this is funny, I ordered a OEM clutch from napa and they sent me the clutch for a 99-02 Honda Accord, how in the hell can they get it that wrong twice yes the sent me two honda clutches so I got my money back. Thats pretty funny you gotta watch napa.
Old 02-27-2009, 06:04 PM   #9 (permalink)
Hop on ebay and look for an AE86 Aisin/Asco clutch should be fun fine for ya! Make sure to get it with throwout bearing. Its good to change that while your in there. Note the AE86 kit comes with a pilot bearing...the fwd doesn't use it.
Old 02-28-2009, 02:58 PM   #10 (permalink)
does it come with both, which means i could just throw the pilot bearing ?
Old 02-28-2009, 03:39 PM   #11 (permalink)
yes, normally hte kit comes with both bearings, you could toss the pilot bearing, or put it on ebay for like 5bux, and make some dough back.
