Flooding problems with Aisan carb 3TC - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla Forum > Older Generations (1969-1987)
Older Generations (1969-1987) Specific discussion of the AE86, along with generations 1 through 5.
Old 02-09-2009, 08:11 AM   #1 (permalink)
Certifiably Insane
96paseo's Avatar
Gameroom cash: $160315
View 96paseo's Photo Gallery
Hello everyone. I've been around TN for a while but I'm new to carbed engines. I'm working on a 3TC that's got a brand new carb and its flooding the engine. I've fixed all the vacuum lines and made sure the two are attached to the distributor. I looked at the window for the fuel and its was about 3/4 covered. Can anyone point me in the right direction to fix it? I'm just not sure what to check. I can see fuel dripping onto the butterfly when cranking it. Here are some pics I took. Thanks for your help.
1996 Paseo 5E-FE 269,xxx miles - Gotta fix that sagging DS door. New hinges on the way.
1993 Camry LE 5S-FE 249,xxx miles - New water pump, TB etc etc
1989 Camry-Gone but not forgotten. Car has become a birthday gift for my cousin.
1997 Mazda B2300 213,xxx miles - New flasher relay installed.
96paseo is offline   Reply With Quote
Old 04-11-2009, 12:34 PM   #2 (permalink)
View Carl H's Photo Gallery
Hi, I have an older 1969 Corona, The gas level needs to be set so the gas is only 1/2 way ( in the center) of sight glass. I had to change the float level by removing the carb top and adjusting the float tang that touches the needle The factory spec is 1/2' from top of float to the carb top surface, I had to make mine .560" to get the fuel level in the center of sight glass. My car would run gas into the manifold and drown the car. It would start cold and run smoothly, but would not start well or at all when it was run (hot) . I could see gas dripping and the manifold would have lots of raw gas in it. Carl H.
Carl H is offline   Reply With Quote
