how do i put a standard in - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla Forum > Older Generations (1969-1987)
Older Generations (1969-1987) Specific discussion of the AE86, along with generations 1 through 5.
Old 02-10-2009, 10:42 PM   #1 (permalink)
mr corollla
anthonynami2's Avatar
View anthonynami2's Photo Gallery
i have a 5 speed manual trans with clutch etc from an 1982 3tc wagon wagon what parts do i need to put on my 1983 4ac automatic and do i need to drill holes for pedals and clutch master cylinder
AnthonyJ.Nami two 1979 corolla coupes 3tc 3kc 3 1982 grey 3tc wagons one 1989 corolla LE sedan
anthonynami2 is offline   Reply With Quote
Old 02-28-2009, 06:46 PM   #2 (permalink)
Nutcase
View nutcase's Photo Gallery
No drilling holes.Find a standard corolla around the same year.Unbolt the pedals which will bolt right up into place where your brake pedal is.You will need a clutch master cylinder which there is a spot on the firewall for that to bolt into also.Then run the clutch lines to the trans slave cylinder.You might also need a driveshaft from a standard trans also. And you might need to bypass the neutral safety switch since the autos will only start in park or neutral.
nutcase is offline   Reply With Quote
