s2k motor in an 86 - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla Forum > Older Generations (1969-1987)
Older Generations (1969-1987) Specific discussion of the AE86, along with generations 1 through 5.
Old 03-11-2009, 11:13 PM   #1 (permalink)
NA>BOOST
ADVANceNA's Avatar
View ADVANceNA's Photo Gallery
s2k motor in an 86
ok so i dont own an 86 but i do like them. more of a fan of the coups. but i heard from some one that a s2 motor would be easy to swap. i wanted to kno if that was true
ADVANceNA is offline   Reply With Quote
Old 03-12-2009, 01:27 AM   #2 (permalink)
noadvertisingplease.com
View Brian's Photo Gallery
No.
It's not easy. It's not cheap.
If you've never had an old corolla, you don't want one. They are slow.
- Brian
Brian is offline   Reply With Quote
Old 03-12-2009, 04:41 AM   #3 (permalink)
on full afterburner
Gameroom cash: $1345097
Check out club4ag, there's quite a few owners on that board that have completed F20C swaps successfully.
Old 03-14-2009, 09:02 PM   #4 (permalink)
5spd FTW!
ariel_86's Avatar
View ariel_86's Photo Gallery
Hater.
swapping in the F20C or F22C is not easy, or cheap, but there is a kit for the mounts. it is gaining some popularity b/c you don't have to resort to forced induction for more horsepower and torque, but it isn't the only weird swap that's been done.
Physics for your head!!
2000 Camry XLE 5-Spd
1985 Corolla GTS Coupe
ariel_86 is offline   Reply With Quote
Old 03-14-2009, 09:32 PM   #5 (permalink)
Moderator
Gameroom cash: $570337
View silver04rollas's Photo Gallery
Better off swapping a 2JZ-GTE in it than the S2K motor.
SSM 05 Corolla XRS 6 Spd VVTL-i 2ZZ-GE /04 Corolla S 1ZZ-FE (sold)
BT: 14.67@96mph(I/E)/Injen Cold Air Intake/Greddy SP2/MT90/GPS Navi/Continental ExtremeContact 205/50/16 track radials/Megan Racing/Koni fully adjustable suspension/Cross drilled + slotted rotors/Carbon ceramic pads/Motegi lightweight rims.
"LFA - Passion, soul and character in its purest form"
silver04rollas is online now   Reply With Quote
Old 03-16-2009, 06:29 PM   #6 (permalink)
5spd FTW!
ariel_86's Avatar
that is harder to do. the 2JZ is an inline 6, which is longer than either the 4A or F20 (which are both I4). a I6 requires custom mounts that aren't readily available (unlike the mounts for the F20/F22), reworking the firewall and trans tunnel to accommodate the motor and transmission, and forces the radiator and intercooler to be mounted in front of the radiator support b/c the motor is so much longer. At least, that is how I saw this one kid that swapped a 1JZ into his corolla do everything.
It can be done, but i'm certain more money would be spent trying to fit everything in and making custom mounts, brackets, and rewelding the front of the car that an S2k motor could be cheaper.
Old 03-16-2009, 07:53 PM   #7 (permalink)
Originally Posted by ariel_86 View Post
Hater.
Au contraire.
Everyone wants to put 200+hp into a corolla they've never even driven.
IMO, buy the car, put an LSD and suspension into it, then learn to drive. Take it to the track. If you can keep the car in one piece for more than a year, consider adding power at that point.
- Brian
Old 03-17-2009, 07:30 PM   #8 (permalink)
5spd FTW!
ariel_86's Avatar
Au contraire.
Okay. I will give you that, and admit I'm guilty of wanting to build up a motor before driving my car at all.
+1 on the learn to drive, LSD, and suspension. no need to worry about power until you maximize those three. Unless you plan on drag racing. then just move over to a better platform don't waist a corolla in straight line.
