If you do not have any external coolant leaks, you may have an internal coolant leak. Either inside the engine, or the heater core into the cabin of the car.
A blown head gasket does not necessarily mix oil with coolant.
Pull out your sparkplugs, and keep them in order. shine a light thru the plug holes and inspect your piston tops. a clean piston or clean sparkplug = possible coolant leakage.
you can also use a cooling system pressure tester to pressurize your rad. Wait 15 minutes and keep it pumped up. Then spin the starter over (with the plugs out) and watch for a spray of coolant out of the plug holes.
- Brian
