wont stay on - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla Forum > Older Generations (1969-1987)
Older Generations (1969-1987) Specific discussion of the AE86, along with generations 1 through 5.
Old 04-27-2009, 03:31 PM   #1 (permalink)
View medic4.life's Photo Gallery
wont stay on
hows it going
i have an 84 sr5 86. So far i been getting my maintenance up to date. I have replaced plugs, wire set, cap and rotor, vacuum advance, few hoses that were cracked, hot idle compesator was clogged so i replaced it and also an oil change was done. I also tried cleaning up the carb with some cleaner at autozone. Last saturday night i was able to start up the car by just turning the key, when it does i just give it lil more gas to keep it alive. When i took at look at the engine bay i just open up the throttle wide open to see how much more cleaning needs to be done. If its open quickly i get a pop out of the intake.
I just left alone, let it idle and drove it around my neighborhood.
The next morning i try getting the car started and it wont budge. I can start the engine but it stumbles i try giving it gas but it doesnt seem to work and it just dies. I try giving it another shot before turning the key i give it 2 pumps on gas and start it. I get the same results, it starts but stumbles i give it gas to keep it alive and it just dies. Thats all i been getting that day. I tried today and same results, i cant figure out whats wrong i have no leaks, hoses that were needed to be replaced have been.
any thoughts?
thanks
medic4.life is offline   Reply With Quote
Old 04-28-2009, 05:23 AM   #2 (permalink)
View Carl H's Photo Gallery
If you have a carb, check the float level, I had crazy, similar problems until I re set the float level to lower the fuel level..CH
Originally Posted by medic4.life View Post
hows it going
any thoughts?
thanks
Carl H is offline   Reply With Quote
Old 04-28-2009, 10:17 AM   #3 (permalink)
Thanks, i got the car started i just covered the intake poured fuel into the carburetor and it started after few tries. The only problem i got is it stumbles a bit at the beginning of the accelaration and it gets better when my revving gets higher.
