According to the Toyota Service Manual for a 1984 ae86 (same as yours). It says the following:
Fuel System: carb problems, float level too low, accelerator pump faulty, power valve faulty, choke valve closed (hot engine), choke valve stuck open (cold engine), fuel line clogged
Ignition System: Spark plugs faulty, IIA (Integrated Ignition Assembly) wiring faulty, Incorrect Ignition Timing
Engine Mechanical: Vacuum leaks, Air Filter, Emission Control System Problem: HAI system always on (hot engine), AAP system faulty (cold engine), EGR system always on (cold engine), HAC system faulty, CMH system faulty, engine overheats, feed back system problems, low compression.
HAI: Automatic Hot Air Intake System
AAP: Auxiliary Acceleration Pump System
HAC: High Altitude Compensation System
CMH: Cold Mixture Heater System
According to that manual it could any of those.
