Corolla diff fluid - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla Forum > Older Generations (1969-1987)
Older Generations (1969-1987) Specific discussion of the AE86, along with generations 1 through 5.
Old 05-11-2009, 08:49 AM   #1 (permalink)
View itburnz's Photo Gallery
Corolla diff fluid
Ok, I got a question regarding the diff that is bolted onto my 3-sp auto transmission; it's an '86 Corolla. What fluid does it take? The Haynes manual says Dexron ATF, but when I had a leak and brought it to a shop (it always happens on trips when you don't bring jackstands along) they filled it with gear oil. I have been running on that for about 4k miles now. Would there be a reason to change it to Dexron?
BTW there's a lot of backlash in the diff and I get a loud thud when going into reverse after stopping; it has been doing this all along. I thought about driving it until the diff dies unless someone knows where I could get a replacement that doesn't cost an arm and a leg and doesn't require me to dismantle a junk-car first.
Thanks!
itburnz is offline   Reply With Quote
Old 05-11-2009, 06:10 PM   #2 (permalink)
Toyota Technocraft
84Hachi's Avatar
View 84Hachi's Photo Gallery
The owners manual calls for 80W-90 Hypoid gear oil. But any 80W-90 Gear oil will work.
84Hachi is offline   Reply With Quote
Old 05-11-2009, 08:23 PM   #3 (permalink)
noadvertisingplease.com
View Brian's Photo Gallery
ae86 RWD takes GL5 75w90 or 80w90
ae82 FWD takes GL4 (ATF) but GL5 gear oil won't hurt a thing, other than a slight change in fuel economy.
- Brian
Brian is offline   Reply With Quote
