is a fan shroud necessary? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla Forum > Older Generations (1969-1987)
Older Generations (1969-1987) Specific discussion of the AE86, along with generations 1 through 5.
Old 06-04-2009, 08:15 AM   #1 (permalink)
View mmlilac's Photo Gallery
Question is a fan shroud necessary?
I have a 1986 Corolla SR5 that's about ready for the junkyard. The fan shroud can no longer be attached as the parts the screws go through have broken off. Do I need a replacement or can I just leave it off?
mmlilac is offline   Reply With Quote
Old 06-04-2009, 06:49 PM   #2 (permalink)
Toyota Technocraft
84Hachi's Avatar
View 84Hachi's Photo Gallery
Well. non AC equipped cars didn't come with the shroud. I would say leave it in. The shroud really helps when stuck in traffic. Helps direct air. And those things that the screws connect to are metal clips with holes in em. They slip over the lower half of the shroud. So they are cheap enough to fix.
84Hachi is offline   Reply With Quote
Old 06-05-2009, 05:50 AM   #3 (permalink)
Actually the holes for the bolts are part of the shroud itself which is plastic. I see I can get a new shroud for $40 but in my opinion the car at this point isn't worth $40. Since half of one hole( wish I knew the correct word for these) is there I was thinking maybe I could tighten the bolt as much as possible and then use some duct tape to hold it. Would the heat of the engine be too much for duct tape or would this be an ok temporary fix?
Old 06-05-2009, 09:18 AM   #4 (permalink)
Danno
View 89yotarollagts's Photo Gallery
if the car isnt worth fixing, dont waste your time or money an leave it off... toyota's cooling system is pretty darn good so long as you keep good coolant in it & your fan is working properly
~Dan
"True car enthusiasts are open-minded to everyone's creation"
"Straight Roads are for Fast cars... Curvy Roads are for Fast drivers "
89yotarollagts is offline   Reply With Quote
Old 06-09-2009, 10:24 AM   #5 (permalink)
View TOYOMaN401's Photo Gallery
AE86 do u still need the plastic belly pan for it to still maintain the temp?
TOYOMaN401 is offline   Reply With Quote
