4 afe in a 86 corolla - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla Forum > Older Generations (1969-1987)
Older Generations (1969-1987) Specific discussion of the AE86, along with generations 1 through 5.
Old 06-05-2009, 03:34 AM   #1 (permalink)
View aerisol's Photo Gallery
getting a 4-afe to go in my 86 corolla just ondering if it will fit straight onto my corolla gearbox or if ill have to get a new one to fit. also any other tips on what im getting myself into e.g problems im likely to encounter. got my step dad helping who has done this sort of thing before so it should work . . eventually
aerisol is offline   Reply With Quote
Old 06-05-2009, 02:00 PM   #2 (permalink)
Wonderbread
4agetercel's Avatar
Gameroom cash: $160040
View 4agetercel's Photo Gallery
waterline re-routing, you need a modded intake manifold too, because the 4afe will have the intake facing the firewall when its in the ae86, is it a gts?
4agetercel is offline   Reply With Quote
Old 06-08-2009, 05:18 PM   #3 (permalink)
View fredricktflail's Photo Gallery
If the 4afe came out of a 93-97 corolla youll need to keep your stock motor mount on the timing belt side from the 4ac, the motor mount is sideways from the 4ac one is the best way to explain it i guss, so it wont mount to the frame. the mount from the 4ac will bolt right to the block since the block is the same pretty much, I myself would use all the old mounts, another thing is the dist is will be facing the firewall which might take some modding, I also herd this from 4acpowered that it takes all the same mods to put a 20v in as a 7afe which isint any differnt really than a 4afe, differnt crank and oil pan a far as i know.
fredricktflail is offline   Reply With Quote
