Key Cylinder Issues - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla Forum > Older Generations (1969-1987)
Older Generations (1969-1987) Specific discussion of the AE86, along with generations 1 through 5.
Old 07-02-2009, 11:37 PM   #1 (permalink)
View Duy-'s Photo Gallery
Key Cylinder Issues
I got an 87 ae86 and i noticed that i can pull the key out while the engine is running. ive noticed this on a lot of the older corollas especially the ones where you have to click it down before it releases and they probably go bad because people forget to and pull the key out at ACCessories. is there a way to pull out the key cylinder and correct this?
Duy- is offline   Reply With Quote
Old 07-03-2009, 07:30 PM   #2 (permalink)
noadvertisingplease.com
View Brian's Photo Gallery
yup
- Brian
Brian is offline   Reply With Quote
Old 07-07-2009, 09:00 PM   #3 (permalink)
View EdgarTRD1.8's Photo Gallery
Change the starter switch, the reason you can pull out the key is by the key wear. The past of the years putting and pulling the key make wear on it and in the starter switch...
EdgarTRD1.8 is offline   Reply With Quote
Old 07-09-2009, 03:49 PM   #4 (permalink)
Beverly Stayart's Avatar
View Beverly Stayart's Photo Gallery
I had the same problem. Changing the starter switch corrected this problem for me.
Beverly Stayart is offline   Reply With Quote
