Toyota Corolla stalling when breaking - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla Forum > Older Generations (1969-1987)
Older Generations (1969-1987) Specific discussion of the AE86, along with generations 1 through 5.
Old 08-25-2009, 12:19 AM   #1 (permalink)
View Sparky343's Photo Gallery
Australia Toyota Corolla stalling when breaking
Hi Everyone
I have a 1986 toyota Corolla. Recently I've been finding that every time I slow down at the traffic lights my car stalls. If I brake suddenly this happens straight away. If I brake slowly the car will sputter first then stall.
What could be causing this problem?
Thanks
Sparky343 is offline   Reply With Quote
Old 08-25-2009, 01:50 PM   #2 (permalink)
Cyd-Wich's Avatar
View Cyd-Wich's Photo Gallery
4th Generation
sounds alot like the vacuum hose for your break booster is either un plugged or has a hole in it. try replacing it cause i have had a few of them do that on me before. hope this helps good luck
Cyd-Wich is offline   Reply With Quote
Old 08-25-2009, 08:12 PM   #3 (permalink)
noadvertisingplease.com
View Brian's Photo Gallery
First try pushing the brake while at idle. If the idle speed changes and stays funky with the brake depressed, you may indeed have a failed brake booster.
What is your idle speed? Sometimes setting idle speed too low will have this effect as well.
- Brian
Brian is offline   Reply With Quote
