Search!
to step up to a fuel injected motor you need to either A) run a return fuel line yourself back into the gas tank, or B) get the gas tank and fuel lines from a GTS corolla and install those in place of your current setup. And while your getting parts from a GTS, you might as well get the rear end, for it's disc brakes, possible OEM LSD and support for an aftermarket LSD, better rear end gear ratio, and additional strength, the bellhousing off the transmission to put the starter on the driver side of the engine instead of the passenger side, or you could just get the transmission as a whole, along with the driveshaft and slave cylinder (cause your SR5 is a manual right? Maybe not? better get the clutch pedal, master cylinder and hard lines too then!)
The short story is, do your homework and decide if you can afford to do it yourself or to pay someone to do it. Then find all the parts to do it. Then do it. An easier swap to do is just a carb'd 4AGE. that eliminates the need for the gas tank.
And swapping in a 3TC gives you loads of options too, despite what others may say.
Knowledge is power, so search for it before you ask too many questions. You aren't the first person to ask about this.
Physics for your head!!
2000 Camry XLE 5-Spd
1985 Corolla GTS Coupe
