Alternator removal from 85 sedan? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla Forum > Older Generations (1969-1987)
Older Generations (1969-1987) Specific discussion of the AE86, along with generations 1 through 5.
Old 11-07-2009, 07:17 PM   #1 (permalink)
View JohnAE82's Photo Gallery
How do you take the alternator off a 4AC ’85 FWD Corolla?
JohnAE82 is offline   Reply With Quote
Old 11-07-2009, 11:34 PM   #2 (permalink)
noadvertisingplease.com
View Brian's Photo Gallery
disconnect battery negative cable
unplug connector on alternator
remove 10mm nut on big white wire of alternator
loosen the alternator mounting bolts
mark belt direction then flip belt off pulley
remove alternator
are you serious?
- Brian
Brian is offline   Reply With Quote
Old 11-07-2009, 11:56 PM   #3 (permalink)
Originally Posted by Brian View Post
are you serious?
No, I just wanted to see who would actually waste there time replying
Actually it’s the mounting bolts I’m having problems with, I can only see one bolt? How many bolts is there?
Old 11-08-2009, 12:01 AM   #4 (permalink)
View fredricktflail's Photo Gallery
Theres 1 bolt that holds it on the block then theres the tensioner. so 2
fredricktflail is offline   Reply With Quote
Old 11-08-2009, 12:06 AM   #5 (permalink)
Ok, I didn’t know the alt was also the tensioner, that’s what threw me off, lol.
Thanks a lot.
