4ALC timing belt fail Valve clearance? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla Forum > Older Generations (1969-1987)
Older Generations (1969-1987) Specific discussion of the AE86, along with generations 1 through 5.
Old 11-22-2009, 08:32 PM   #1 (permalink)
GIBEYERSON's Avatar
View GIBEYERSON's Photo Gallery
So, I'm wondering when I should replace my timing belt. The motor has 115,000miles and sat for 6 years. I don't know if it was ever replaced. When these belts slip / fail will the piston hit a valve?
GIBEYERSON is offline   Reply With Quote
Old 11-22-2009, 11:43 PM   #2 (permalink)
No More Turbos!
View Pwner Guy's Photo Gallery
Well those old Toyota timing belts had a recommended replacement interval of 100,000 KM or 60,000 Miles so I'd say at the least its due for another one if it was done once. I can't recall if the 4A-LC was interference or not, I'd have to look it up at the shop. But if it breaks it and its non-interference then its going to be a very big annoyance. Honestly I'd say just replace it along with all the other belts since it has been sitting and they're coming off anyway. So depending on the options you're looking at 1 to 3 accessory belts if I remember correctly and a timing belt. Well worth it for a little piece of mind.
Pwner Guy is offline   Reply With Quote
Old 11-23-2009, 04:33 AM   #3 (permalink)
GIBEYERSON's Avatar
So is it interference or not ?
That is the question. I know I need to change it. I've done so much to get this car back on the road, I want to drive it for a while before I tear it apart again. So can the piston hit the valve when the timing belt fails?
Old 11-27-2009, 06:09 PM   #4 (permalink)
Owner of much Obsolete
Jeff Lange's Avatar
Gameroom cash: $412712
View Jeff Lange's Photo Gallery
The piston will not hit the valve if the belt breaks.
Jeff
2011 Lexus IS250 Obsidian "F-Sport 6MT" with LSD
1986 AE86 Corolla GT-S Supercharged
Jeff Lange is offline   Reply With Quote
Old 11-27-2009, 06:16 PM   #5 (permalink)
View toytec's Photo Gallery
^^^ Like he said!
toytec is offline   Reply With Quote
Old 11-27-2009, 10:25 PM   #6 (permalink)
GIBEYERSON's Avatar
Thanks
Thanks it is on my list of things to do. I was wondering where on the list to put it. I think I'll wait for nicer weather.
