Carb Problem = fuel system failure - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla Forum > Older Generations (1969-1987)
Older Generations (1969-1987) Specific discussion of the AE86, along with generations 1 through 5.
Old 11-26-2009, 07:20 PM   #1 (permalink)
GIBEYERSON's Avatar
View GIBEYERSON's Photo Gallery
I found out what has been driving me crazy! My tank is not venting properly. Fuel in the filter can't get to the carb because the system is vapor locked. I had the tank down three times and the carb off or apart more than I can count.
I hope this info helps someone else.
GIBEYERSON is offline   Reply With Quote
Old 11-27-2009, 08:37 PM   #2 (permalink)
kathyricks's Avatar
View kathyricks's Photo Gallery
You didn't explain why your tank was not venting properly nor what you did to fix it. So you havn't helped anyone.
kathyricks is offline   Reply With Quote
Old 11-27-2009, 10:34 PM   #3 (permalink)
GIBEYERSON's Avatar
If someone would have told me to check for the possibility of a vapor lock sooner I would have gone through less trouble.
The temporay fix was real hard I just leave the cap loose. The vent / emmission tubing sankes around under the rear of the car and then goes to the engine compartment. My car sat for 6 years so I bet it rusted solid someplace.
