??? Oxygen Sensor bad symptoms - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla Forum > Older Generations (1969-1987)
Older Generations (1969-1987) Specific discussion of the AE86, along with generations 1 through 5.
Old 12-13-2009, 08:04 PM   #1 (permalink)
GIBEYERSON's Avatar
View GIBEYERSON's Photo Gallery
Someone told me mine might be bad. Problems started when I replaced a head pipe and muffler. The car started running rougher and rougher. Idle is high so it runs but not smooth. On the highway it hums along until I lift slightly off the throttle. Then it stumbles which is pretty annoying. If I lift my foot off the accelerator it isn't as noticeable. The new parts on the exhaust system have black soot showing at the seams where the pipes join and at the exhaust tip. The head pipe seems to have a void at the transition from head pipe to flex section and the is black soot there as well. I have already cleaned the plugs which had a buildup on them.
I was thinking the catalitic converter was going bad but I've been told to check the choke (which is fine) and the O2 sensor.
Thanks in advance for your opinion.
GIBEYERSON is offline   Reply With Quote
Old 01-08-2010, 07:38 PM   #2 (permalink)
Gameroom cash: $197815
View Frodo65's Photo Gallery
Are you sure you don't have an exhaust leak that results in excess air getting in? Extra air would be misread as a lean condition, causing the ECU to enrich.
The main reason I suggest that is because of the exhaust work - which carries a risk of gasket compromise on an old car..
Frodo65 is offline   Reply With Quote
Old 01-08-2010, 08:04 PM   #3 (permalink)
GIBEYERSON's Avatar
Thanks for that suggestion. Since I posted that I had one good day to work on it and I lowered the float level. I seemed to get just a little bit better. The new flex pipe does have a void where the flex section starts and I'm going to have my bro-inlaw weld it when the weather improves. The car humms along great on the interstate but because of the stumble I find my speed constantly increasing. That is how it runs best. If I lift just a little it shudders slightly.
Old 01-08-2010, 08:34 PM   #4 (permalink)
View CRASHDRIVE's Photo Gallery
check also the EGR maybe needs cleaning or replacing
CRASHDRIVE is offline   Reply With Quote
Old 01-09-2010, 03:48 PM   #5 (permalink)
View fredricktflail's Photo Gallery
Gen5
My car was doing the same thing, It had to do with the wrong vac line being hooked to the egr valve.
fredricktflail is offline   Reply With Quote
Old 01-09-2010, 07:51 PM   #6 (permalink)
GIBEYERSON's Avatar
That sounds probable. there are so damn many of them. When the weather gets nice again I'll check that.
thanks
Old 01-16-2011, 08:23 PM   #7 (permalink)
View MyCorolla's Photo Gallery
I'm worried I may have that problem right now. Anybody have pictures of the proper EGR hose routing for a 1978 Toyota Corolla Wagon, 2TC, 5 speed?
MyCorolla is offline   Reply With Quote
