My riced out toys - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla Forum > Older Generations (1969-1987)
Older Generations (1969-1987) Specific discussion of the AE86, along with generations 1 through 5.
Old 01-07-2010, 04:09 PM   #1 (permalink)
View CRASHDRIVE's Photo Gallery
My riced out toys
First off I'm open for comments to improve the lap time, for looks I don't really care much so will just stay with performance.
First AE86: It started as a cheap project to test a hybrid 4ag engine 3 yrs ago, turned out engine and chassis was good together so we just keep it and improve on that base line. can't really tell you more about the engine.
suspension its typical DIY coilover w/ used 10kg springs front & 8kg rear w/ a used camber plates on a RCA, used whiteline sway bars front/rear, used 4 links w/ lat. bar by battle version.
Drive train took much of the budget 7lbs fly wheel, kevlar clutch w/ heavy duty pressure plates on a 2 way lsd
looks nothing much something cheap so a J blood knock off will do.
we wanted to know how the engine will perform on 9,200rpm track environment so we took it to willow springs on the club4ag 4ag challenge. now we decided this chassis will be strictly for the TCRA time attack.
tested it also on drifting and gymkhana
Second AE86: This project was done around 2004 started late 2002, it was more like a dare of my friend that a AE86 can't go faster than his S2000. rule was cant swap a motor with a bigger liter like a 3sgte, so end up with a 4agze from an AE101 Japanese spec. w/ a HKS supercharger kit w/ the HKS all bottom end on a all out TODA head everything is controlled by a aerodyne ind. stand alone ecu all the way to 9,200rpm. this project became a no holding back all out performance suspension, breaking & drive train. end up the AE86 was 2.3sec faster than my friends S2000 in willow springs.
CRASHDRIVE is offline   Reply With Quote
Old 01-07-2010, 08:03 PM   #2 (permalink)
5spd FTW!
ariel_86's Avatar
View ariel_86's Photo Gallery
...uh, what's the lap time you're trying to beat? From the limited amount of info you've given regarding such, and the fact that you seem to know how to build a car, focus on tires and seat time. Become a better driver and your lap times should go down. Use better tires and you should be able to push the car harder. And then there's dialing in the suspension. This part is still a mystery to me, but that would be where I suggest you look into for improvements without changing parts (except tires).
But nice cars man. Very nice.
Physics for your head!!
2000 Camry XLE 5-Spd
1985 Corolla GTS Coupe
ariel_86 is offline   Reply With Quote
Old 01-07-2010, 08:32 PM   #3 (permalink)
Automotive Lighting Guru
gold94corolla's Avatar
Gameroom cash: $291352
View gold94corolla's Photo Gallery
What? Where are the riced-out toys??? Looks GREAT man!! and fast too!
oh wait, haha you're the guy who called my car the definition of rice!! HAHAHA
Well, that does not change anything! Even if you're not very nice I still think your cars are sweet!
gold94corolla is offline   Reply With Quote
Old 01-07-2010, 08:51 PM   #4 (permalink)
Thanks, seat time I already have at lest 9 time attack event on the red corolla, even my friend who is a TCRA instructor he can't even beat my time on my car. but yeah 205/50/15 on a advan A048 kinda ok, I got this 14x11 -23 hope I can find a slicks for them at least a 225/50/14 but I'm really hoping a 255/50 but cant find a tire for them yet O yeah my problem with them is I dont like flairs and if I put this I may not have any choice.
Thanks
Old 01-07-2010, 10:35 PM   #5 (permalink)
on full afterburner
Gameroom cash: $1345097
uber-clean AE86s!
I would love to have one myself one day as a project.
Old 01-07-2010, 10:57 PM   #6 (permalink)
Originally Posted by PhatRoyale View Post
uber-clean AE86s!
Thanks, AE86 are nice project easy to work on but expensive, then again everything is expensive this days. Its a very good teaching car to start you on auto cross, road racing & drifting.
Old 01-08-2010, 12:11 PM   #7 (permalink)
That Acura Guy
TTercel's Avatar
Gameroom cash: $267565
View TTercel's Photo Gallery
Nice cars, what did you mean by hybrid 4ag?
TTercel is offline   Reply With Quote
Old 01-08-2010, 12:57 PM   #8 (permalink)
View daviidsjdmx's Photo Gallery
.................................................. ... yea i remember you now, where have you been man?! havent seen the 86
for like 2 years?!
daviidsjdmx is offline   Reply With Quote
Old 01-08-2010, 04:46 PM   #9 (permalink)
basically we took all the good parts from different 4ag's like the strength of the silvertop 20V ae101 block, a light weight crank, light weight connecting rod from a blacktop 20V AE111, high flow big port head from a 16V bluetop, ITB's from the silvertop 20V, pistons, harness & ecu from a high compression redtop 16V. all that made 11.5:1 compression ratio .5 more than a regular blacktop 20V 4ag.
A lot of people asked me this why not just get a 20V blacktop change the piston to something higher to bump up the compression add? well are point was not really the compression ratio, we are actually trying to make a motor that has a good mid to high range of trq. and a very good engine response we didn't even know will end up with a higher compression its just like the icing on the cake.
for like 2 years?!
we rented out the condo in mission valley and went back to the house in ej cajon at least i have a garage to work on my cars now lol I'm sad now cuz, my AE86's are track use only so can't take it out
Old 01-09-2010, 05:17 PM   #10 (permalink)
Forgot my 4agze motor pic sorry
