ae86 welding rear diff question... - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla Forum > Older Generations (1969-1987)
Older Generations (1969-1987) Specific discussion of the AE86, along with generations 1 through 5.
Old 01-30-2010, 12:19 AM   #1 (permalink)
View ChiGz's Photo Gallery
I was wondering if you need to take the diff out in order to weld an open diff, or whether it can be done in the car.
Thanks
Chris
ChiGz is offline   Reply With Quote
Old 01-30-2010, 01:11 PM   #2 (permalink)
Bitter's Avatar
Gameroom cash: $558900
View Bitter's Photo Gallery
you will not be able to turn the car without destroying either the diff, axles, or tires. it will at that point only be able to go in a straight line, not be street driven, and be a trailer queen.
Old 01-30-2010, 01:21 PM   #3 (permalink)
noadvertisingplease.com
View Brian's Photo Gallery
Removal is the proper way. Remove rims, brakes, axles, propshaft, pinion snubber (bumpstop) then pull the diff out.
Degrease, and weld away. Don't get spatter on the ring gear or bearings.
Clean off the old gasket thoroughly.
Put it back with a small (2mm) bead of silicone sealant or Toyota FIPG.
If you're building a demolition derby car, you can stick weld thru the filler hole if you're crafty. But they tend to stop working after a couple hours
- Brian
Brian is offline   Reply With Quote
Old 01-30-2010, 02:27 PM   #4 (permalink)
Thanks brian.
Bitter, that was not my question.
chris
Old 01-30-2010, 05:36 PM   #5 (permalink)
View CRASHDRIVE's Photo Gallery
I wouldn't even advise doing a welded diff.
CRASHDRIVE is offline   Reply With Quote
Old 01-30-2010, 09:12 PM   #6 (permalink)
Owner of much Obsolete
Jeff Lange's Avatar
Gameroom cash: $412712
View Jeff Lange's Photo Gallery
Pinion shaft removed, solid sleeve machined to size, entire diff heated to allow proper penetration, then welded:
At this point, it's going to be the axles or tires that break, haha.
Jeff
2011 Lexus IS250 Obsidian "F-Sport 6MT" with LSD
1986 AE86 Corolla GT-S Supercharged
Jeff Lange is offline   Reply With Quote
Old 01-30-2010, 09:31 PM   #7 (permalink)
nice job Jeff
Old 01-31-2010, 02:43 PM   #8 (permalink)
Neither would I, but that wasn't the question.
We install a lot of limited slip diffs here, but the occasional drift car has a mexican posi.
- Brian
Old 01-31-2010, 11:49 PM   #9 (permalink)
Jeff Lange's Avatar
Agreed. That diff isn't even in a car right now, haha. It was welded simply because it was lying around doing nothing. It is now setup in a 3rd member, sitting there waiting for some testing .
I've driven with a welded diff around town, it's not nearly as bad as most people say. Still I would never do it in my own car, ever.
Jeff
Old 02-03-2010, 12:46 PM   #10 (permalink)
No More Turbos!
View Pwner Guy's Photo Gallery
I remember when my cousin had his '80 Malibu with the 455 in it. After we welded up the diff the easiest way to go around a corner was to give 'er gas.
Richard Hammond - You can stick a BMW badge on a dead cat... And people would still buy it.
Pwner Guy is offline   Reply With Quote
