5spd swap on an AE86 with 4ac - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla Forum > Older Generations (1969-1987)
Older Generations (1969-1987) Specific discussion of the AE86, along with generations 1 through 5.
Old 02-04-2010, 09:53 PM   #1 (permalink)
View 2jzrps13's Photo Gallery
AE86 5spd swap on an AE86 with 4ac
i just picked up an AE86 for cheap and its and auto so need it 5 speed... has anyone done this and whats the budget?
2jzrps13 is offline   Reply With Quote
Old 02-05-2010, 02:44 AM   #2 (permalink)
View CRASHDRIVE's Photo Gallery
questions first, are you keeping the 4AC motor or on the future you'll also swap a 4ag w/ a GTS rear end? why I ask, it will be easier to convert everything on one big swap... I help a club4ag member back then to convert his SR5 coupe AT to a 16V 4ag w/ a 5 speed manual. well if you do a 4ag swap you'll need a GTS or SR5 5 speed transmission w/ drive shaft, 4age motor w/ a uncut wire harness, ECU, manual transmission pedals set (they say a AW11 MR2 are same as the GTS pedals but not 100% sure never done it but i was reading a topic about it years ago) and if you want a GTS gas tank w/ fuel lines (or just keep your original fuel tank and run a external fuel pump but its up to you what you want)... O yeah a GTS rear
advice only: do it one big swap, less work and time
CRASHDRIVE is offline   Reply With Quote
Old 02-24-2010, 03:58 PM   #3 (permalink)
ayang951's Avatar
Gameroom cash: $163050
View ayang951's Photo Gallery
i have a extra 5spd tranny in my garage, if u want to buy it, hit me up, my email is anthonyyang951@hotmail.com. lets talk if ur anywhere near me in socal. im in inland empire in the riverside county area.
ayang951 is offline   Reply With Quote
Old 02-25-2010, 10:05 PM   #4 (permalink)
View fredricktflail's Photo Gallery
The budget depends on where you get your parts. You need the 5-speed 4A-C flywheel unless your swaping engine at the same time. Clutch kit, The master and slave cylinder and the pedal of course and maybe even the safty switch, I dont know if you need a driveline somebody else will know. I'm having troble remembering what else you need.
fredricktflail is offline   Reply With Quote
