transmission problem on my FX16 with 4ag? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla Forum > Older Generations (1969-1987)
Older Generations (1969-1987) Specific discussion of the AE86, along with generations 1 through 5.
Old 02-10-2010, 02:17 AM   #1 (permalink)
View 2jzrps13's Photo Gallery
i just did a clutch on my FX and for some odd reason 4th and 5th gear are not working its grinding really bad what could this be?
2jzrps13 is offline   Reply With Quote
Old 02-14-2010, 10:56 AM   #2 (permalink)
not12listen's Avatar
View not12listen's Photo Gallery
honestly... thats a tough one.
if you had the problem previously, then i'd say that its the synchros in your transmission. and from what i know, replacing the clutch would have no impact on it at all...
and, if you didn't properly bleed the clutch, you'd most likely get that grinding in all gears.
so... tackle the easiest stuff first.
1. re-bleed the clutch.
2. drain and replace the transmission fluid.
anything beyond that, are you're looking at (most likely) removing the transmission, etc.
not12listen is offline   Reply With Quote
Old 02-15-2010, 11:24 AM   #3 (permalink)
View fredricktflail's Photo Gallery
Just cause it's only 1 or 2 gears that grind dosent mean its not the clutch. Do what the last guy said. If that dosent work look into the shift cables. A friend of mines ae-102 would grind 2nd and 4th and wouldent even go into reverse he had a shot shift cable. So its the clutch, linkage, or a internal trans problem.
fredricktflail is offline   Reply With Quote
Old 02-16-2010, 11:56 PM   #4 (permalink)
hey guys thanks i think ill try it and bleed the brakes because i didnt bleed them what so ever... but why did reverse was working and than it stoped working?
