aftermarket cam question - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla Forum > Older Generations (1969-1987)
Older Generations (1969-1987) Specific discussion of the AE86, along with generations 1 through 5.
Old 04-01-2010, 08:04 PM   #1 (permalink)
View le272's Photo Gallery
what are the advantages of running a "larger" exhaust cam?
for example running a "256" on the intake side and a "264" on the exhaust side?
my engine is a 4age.
le272 is offline   Reply With Quote
Old 04-05-2010, 10:31 PM   #2 (permalink)
anyone??? i dont want to get slammed asking this on club4ag and/or hr.net.
Old 04-05-2010, 11:59 PM   #3 (permalink)
Wonderbread
4agetercel's Avatar
Gameroom cash: $160040
View 4agetercel's Photo Gallery
its not really larger, the duration (256,264) is how long the valve is held open, the lift is most likely the same.... but i dont know what advantages of running this setup would be
4agetercel is offline   Reply With Quote
Old 04-06-2010, 09:15 PM   #4 (permalink)
thanks for responding.
as u can tell i'm a n00b. i've read on other forums people using this setup but i cant seem to find the right word combination when i use the search functions on those forums to read about this topic.
anyways thanks again your response is appreciated.
Old 04-22-2010, 06:35 PM   #5 (permalink)
View Carl H's Photo Gallery
Hi, try using words like cam duration degrees, cam lobe center. Search aftermarket cam manufacturer brand names to see what they offer.
I suppose most all cars will gain a little horse power with moderate cam duration improvements, but you might gain on top and lose on the bottom. Plus cams can be costly to install and could entail other performance valve train parts to go with the cam.
the way I look at it, it the motor pulls to redline,what more do you want. Most are better off with stock cams.
Carl H is offline   Reply With Quote
