FX16 4AGE axle help! - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla Forum > Older Generations (1969-1987)
Older Generations (1969-1987) Specific discussion of the AE86, along with generations 1 through 5.
Old 05-12-2010, 04:34 AM   #1 (permalink)
View webyosan's Photo Gallery
Both of my axles needs replacements, and they are the bolt on and off axle type. I order from a local auto shop (baxter) and they got me the type of axle that snaps in the tranny for the right car: 87 FX16. Then I went to a different store(CSK) one and they seems to have the bolt on axle type. I bought it it doesn't fit..The holes for the bolt is wrong and the diameter of the end shaft is smaller to the original ones (FWD Corollas?)..Is there a right part number for it or did Toyota decide to have the snap on type of shaft? Almost there to get my car running...
webyosan is offline   Reply With Quote
Old 06-06-2010, 02:44 PM   #2 (permalink)
View mightrolla's Photo Gallery
I had the same problem. Couldnt find the right ones. I just endup rebuilding mines. Should check around to see if there a place near you and get a qoute.
mightrolla is offline   Reply With Quote
Old 06-12-2010, 04:30 PM   #3 (permalink)
corolla254
corolla254's Avatar
View corolla254's Photo Gallery
what you can do is write down the vin number off of the vehicle and call the dealer for part numbers, most auto parts store can cross refrence the number.
corolla254 is offline   Reply With Quote
Old 06-20-2010, 09:50 AM   #4 (permalink)
I did my research and found out the right part number by calling the company that rebuild the axles..I did take a look on the old axles and it looks very easy to re-build one.
