2tc vacuum problems and fuel problems - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla Forum > Older Generations (1969-1987)
Older Generations (1969-1987) Specific discussion of the AE86, along with generations 1 through 5.
Old 05-17-2010, 06:13 PM   #1 (permalink)
littledm's Avatar
View littledm's Photo Gallery
2nd Generation 2tc vacuum problems and fuel problems
I have a 77 corolla with a 2tc engine. i just bought it friday. the previous owner pulled out all egr and vacumm lines. it runs if you spray starter fluid in it. i fixed all the fuel lines and added a couple of vacuum lines. one going to fuel pump regulator. plugged off a couple lines. it gets fuel now in the bowl but will not stay running. have a chilton book but it is not helpfull at all. thank you for all of your future help.
littledm is offline   Reply With Quote
Old 05-17-2010, 08:26 PM   #2 (permalink)
Mad Scientist
2wickedtoyz's Avatar
Gameroom cash: $248601
iTrader Score: 9 reviews
View 2wickedtoyz's Photo Gallery
the carb may need a rebuild. easy to do. take it out and bring it into your kitchen and take your time to redoit
[url]http://www.cardomain.com/id/wickedtoyz[url]
Camry Wagon Crew
2wickedtoyz is offline   Reply With Quote
The Following User Says Thank You to 2wickedtoyz For This Useful Post:
littledm (05-18-2010)
Old 05-18-2010, 05:38 PM   #3 (permalink)
littledm's Avatar
2nd Generation
Thank you for your quick response. I kinda figured it did. my biggest problem now will be the vacuum lines. I am woudering what the minimum number of lines needed and if the fuel reg needs to go to a certain port or if any manifold port will do. also it has a aux fuel injector port for cold starts. Does it need this or if i can do without. Thank you all for your time and input.
Old 05-18-2010, 05:54 PM   #4 (permalink)
Mad Scientist
on my old 3tc i had an electric fuel pump that i installed and a fuel pressure regulator that i also installed. i took out all the hoses but the one for the brake booster and the dizzy
Camry Wagon Crew
Old 05-19-2010, 12:59 AM   #5 (permalink)
littledm's Avatar
Ok, i pulled the carb off jst taking a lookat it. pulled air horn and float off. the float is new. pulled out the jets and they are clear. Whats the chance the fuel cutoff soleinoid is bad? I am getting power to it but feel and hear no click. can i just pull it out and plug off hole with a bolt or do i need to find a new one? tommorow i will try to pull it out of the carb and check it that way. Thanks again.
Old 06-01-2010, 12:56 AM   #6 (permalink)
littledm's Avatar
Update... Rebuilt carb after getting it running, replaced tires, rebuilt tailight lens(could not find redily available replacements so chopped up some prelude lenses). Thank you for your help.
Old 06-07-2010, 02:51 PM   #7 (permalink)
Mad Scientist
awsome
Camry Wagon Crew
Old 01-16-2011, 08:17 PM   #8 (permalink)
View MyCorolla's Photo Gallery
Did you do something before getting it running, that made it run, that you did not previously mention?
MyCorolla is offline   Reply With Quote
Old 01-17-2011, 03:51 PM   #9 (permalink)
littledm's Avatar
Turns out the fuel lines were bad from sitting for so long. Still not quite running right but im not that great with carbs.
