Actually it turns out that it's very easy to repair the charcoal canister. The problem with it is fuel-varnish deposits on the spring of the No. 1 check valve. You can easily dissolve the varnish deposits using Gumout carburetor & choke cleaner, a hose attached to the tank port, and a compressed-air gun (up to 100 psi compressed air). There is no need to bypass the charcoal canister and vent the tank vapors into the atmosphere through an external check valve, which results in increased pollution and decreased fuel economy.
I've posted the detailed instructions on how to correctly do this at a new thread
here.
Rick, thank you for getting me into doing this repair. It was the last thing on my engine that had to be done. It now runs as good as new.
Also note that part of the problems with hot starting on 4A-LC engine is inherent and due to improper choke action. Since the choke is vacuum-controlled, it takes a while for the vacuum to form and the choke opener to function. The bimetal in the automatic-choke housing also cools down and closes the choke, adding to the problem. The owner's manual instructs to fully depress the accelerator when cranking a hot engine but this is detrimental to the engine as it would rev like crazy -- so do
not do this.
I've figured out that the best way to start a hot 4A-LC engine is to depress the accelerator only very slightly before and during cranking and keep it very slightly depressed until the engine starts running smoothly.
