77 COROLLA performance - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla Forum > Older Generations (1969-1987)
Older Generations (1969-1987) Specific discussion of the AE86, along with generations 1 through 5.
Old 08-03-2010, 08:12 PM   #1 (permalink)
littledm's Avatar
View littledm's Photo Gallery
2nd Generation 77 COROLLA performance
OK, I have a 77 corolla sr5 2t-c. Already pulled everything off engine thats not nessisary for daily driving.
Ive already got a 4into1 header comin wich i will run 2.5 all way bck through a "stock style" muffler.
Big question is, to get 150 hp at 4000rpm or so what would be needed. No side draft or weber carbs though. Prefer a single shaft carb W/O choke.
Im looking at a holley 350cfm. Or a stock from a nother vehicle. just dont want emissions crap on it.
Any input would be appreciated.
littledm is offline   Reply With Quote
Old 08-04-2010, 07:42 PM   #2 (permalink)
littledm's Avatar
2nd Generation
Found a weber i might actually use.Its a weber 32 dfe off of a 68 cornita gt.
I dont know if it will be bigger than stock but looks like it might be easier to tune.
Old 08-12-2010, 12:23 PM   #3 (permalink)
tron1.8's Avatar
View tron1.8's Photo Gallery
To get 150 HP out of a stock 2TC you will need a little boost or laughing gas. My 3TC with header,five finger intake and Weber 32/36 was still only around 100 HP.
1981 Corolla Sedan- Sold
1993 Pickup 22RE-82 Supra AFM/battery flip
2010 Corolla LE
tron1.8 is offline   Reply With Quote
Old 08-13-2010, 01:44 AM   #4 (permalink)
littledm's Avatar
Thanks its nice to get a realistic umber to start with. I guess ill start lookin for a M series to replace mine with. Any body know where i can find a cheap 3M engine??
Old 08-16-2010, 05:50 PM   #5 (permalink)
littledm's Avatar
Bump.
Old 09-10-2010, 02:13 PM   #6 (permalink)
JDMuscle84's Avatar
View JDMuscle84's Photo Gallery
Sorry to blow it for you, but you will never find a 3m...
JDMuscle84 is offline   Reply With Quote
Old 09-14-2010, 06:41 PM   #7 (permalink)
littledm's Avatar
I figured i would never find one, or at least one i can afford.
I do have a weber 32/36 that i just got finished rebuilding. The shafts were frozen so i did a complete rebuild. The jetting on it is stock and both shafts work smoothly now.
Just got to get this adapter adapted to my manifold. Its for some other car but i can make it fit.
My biggest problem now is eliminating the points and getting gas gage working. Any tips on the gas gage would be greatly appreciated.
And thanks for all of the help. I dont think my car would have lasted this long without it
Old 09-15-2010, 09:02 AM   #8 (permalink)
tron1.8's Avatar
I have a five finger manifold and adapter that I had on my 81 Corolla that I'm selling for $150- just let me know.
2010 Corolla LE
Old 10-20-2010, 03:24 PM   #9 (permalink)
View Tbermy's Photo Gallery
I'm sorry but 150hp@4000rpm require to produce 197 ft/lbs of torques at 4000rpm even with a multivalve DOHC cylinder head and 13:1 compression ratio, a 4 cylinder 1.6L will never ever make more than 170 ft/lbs, even at 100% VE... why are you looking at so much power so low on the powerband...???
150hp is achivable on a 2t-c, but you are looking at high duration cams along with big valve and all the hardware that's needed with it (stiffer valve spring, stiffer pushrods...), high compression piston and a good intake system, along with a tuned exhaust system and most importantly a good porting job... and even with all this, you'll need to rev the engine 7000rpm+ in order to put down those numbers...
or you could keep your stock compression, strap a small turbo like a T2 on a custom exhaust manifold, and make a sucktrough design with the carb connected before the turbo and the turbo directly on the intake manifold... keep the boost low (under 6 psi) and tune it, it will probably never do 150hp... more like 120hp, but this is the only way I can think off that would be cheap and give a good up in the mid rev area, without going all balls out for a "real" turbo build... but that would be a complete other story...
Tbermy is offline   Reply With Quote
