corolla fx swap? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla Forum > Older Generations (1969-1987)
Older Generations (1969-1987) Specific discussion of the AE86, along with generations 1 through 5.
Old 10-07-2010, 10:18 AM   #1 (permalink)
View blulightandabat's Photo Gallery
corolla fx swap?
i was wondering if a 4ac fx 5speed would bolt up to a 4age motor? i have a corolla gts and am thinking of buying this 4ac fx with a manual trans and putting the 4age in the fx.
blulightandabat is offline   Reply With Quote
Old 10-07-2010, 03:20 PM   #2 (permalink)
Rotary guy...
eage8's Avatar
Gameroom cash: $434050
View eage8's Photo Gallery
yup, they'll bolt up.
'81 BMW R65
The Following User Says Thank You to eage8 For This Useful Post:
blulightandabat (10-07-2010)
Old 10-07-2010, 03:48 PM   #3 (permalink)
any idea how hard the swap is to do?
Old 10-16-2010, 06:49 PM   #4 (permalink)
Donald's Avatar
Gameroom cash: $201420
View Donald's Photo Gallery
It is not easy.
You will need to swap the 4A-GE ECU and wiring also. That is the hardest part.
If you are good with wiring diagrams you could do the wiring yourself.
If not, I would suggest you send the wire harnesses to Tweak'd performance (Dr. Tweak) and for about $400 he will send you back a harness that will plug into everything.
You also need to consider though, that the plain FX does not have a FI fuel pump. That can be overcome by using an "inline" pump.
I did something similar with a Tercel, but if I let it go below 1/4 tank, it would suffer from fuel starvation in wide left turns. This was because the Tercel had the pick-up on the left side of the tank.
The FX has the pick-up in the middle of the tank so it might not be so sensitive to low fuel quantity.
If you can get the tank from an FX-16 or FX-16 GT-S, that would be better.
If you decide to use an in-line pump, the one I used was a Master E8445 from Advance Auto Parts. It put out 35psi, and delivers 45-65 gallons per hour.
'88 Corolla, AE92 SR-5, 7A-FE swap/GT-S suspension
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
Donald is offline   Reply With Quote
