Help with my 83 corolla - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla Forum > Older Generations (1969-1987)
Older Generations (1969-1987) Specific discussion of the AE86, along with generations 1 through 5.
Old 11-05-2010, 10:55 AM   #1 (permalink)
View gelli69's Photo Gallery
Hello all, I have a question...this morning my 83 corolla the charge light comes on when I'm accelerating and starts to blink. Does anyone know why this would be? Please help. Thanks in advance
gelli69 is offline   Reply With Quote
Old 11-05-2010, 05:53 PM   #2 (permalink)
Gameroom cash: $816401
View zythr's Photo Gallery
Alternator could be on the way out
zythr is online now   Reply With Quote
Old 11-05-2010, 06:38 PM   #3 (permalink)
30 yrs of Car Photography
hairball's Avatar
View hairball's Photo Gallery
I agree totally!
It could be a lose connection, but I doubt it. I'd have it checked out. If you have access to a voltmeter you can check it yourself to make sure it's charging. Let us know what you find out.
By the way, "Hairball" was a cat of mine.
Since I don't use the "GameRoom", can you just send me a check?
hairball is offline   Reply With Quote
Old 11-07-2010, 01:55 AM   #4 (permalink)
Full Throttle
Kiwi-Corolla's Avatar
Gameroom cash: $953415
iTrader Score: 16 reviews
It definitely sounds like it could be your alternator. However, the first thing I'd check is the alternator belt. Make sure that it's tensioned correctly and isn't worn. Then check that the wiring harness for the alternator is secured tightly, and not burnt or cut in any way. If everything checks out ok then it's time to test the alternator with a multimeter.
With the engine off, connect the multimeter to the battery terminals and make sure you have at least 12 volts. Now start the engine and check the battery voltage again. It should be between 13.5 to 15.1 volts. Now turn on the headlights. The voltage should drop and then come back up if the charging system is working properly.
I'd recommend taking the car to an auto electrician and getting the problem professionally diagnosed. Most places do the diagnosis for free. They have all the right equipment to do proper tests (such as an amperage output test) on the charging system. Good luck!
