4age Oil pressure sender wire ,no Light ,no pressure on gauge - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla Forum > Older Generations (1969-1987)
Older Generations (1969-1987) Specific discussion of the AE86, along with generations 1 through 5.
Old 11-07-2010, 03:32 PM   #1 (permalink)
View Levin_'s Photo Gallery
AE92 4age Oil pressure sender wire ,no Light ,no pressure on gauge
Hi guys
Im new to this blogging stuff but anyway.. I own a ae92 87 Levin, 4age blue-top
owned the car for about 6months the gauge for the voltmetre has always worked and oil pressure has never worked
I searched up on this last night and didn't find anybody with the same problem
i riped the dash out yesterday found that the gauge and voltmeter are pluged together
looked at my oil pressure sender today earth the wire nothing happend to the gauge. ran a test light through the oil pressure sender wire to ground nothing happend
is there a fuse or anything else that the gauge and sender have in there circut?
i would really like geting my gauge to work
my wire was reasonably shabby but connected.
the wire that was hooked up to the sender i snaped right at the clip and also further up so ill be getting a new wire today if anynody knows where to get a new clip for it in NZ auckland that would be cool to
Levin_ is offline   Reply With Quote
Old 11-07-2010, 03:53 PM   #2 (permalink)
CERTIFIABLE CAR NUT
Zembonez's Avatar
Gameroom cash: $613331
View Zembonez's Photo Gallery
The wire going to the sending unit should not have 12v. It is a ground (earth) wire. The sending unit varies the resistance to ground and sends the corresponding signal to the gauge. It sounds as if your gauge isn't working or is not getting power.
Hope that helps.
Zembonez is offline   Reply With Quote
Old 11-07-2010, 04:10 PM   #3 (permalink)
ive heard that if they fail they read full pressure. and also the volt meter is hooked up through the same cluster and thats always worked
any body ever had this
if the oil pressure sender fails what happens will i have no oil warning light now that i snaped that wire?
Old 11-07-2010, 09:59 PM   #4 (permalink)
ok i got a new wire im not sure if i need a new oil sender or what?
i got told my oil sender was for a light
what does my oil light look like i dont think i have one
the wire that is connected to the oil pressure sender is working but does it go to the dash Oil light (dont think i have one) or the gauge
but i dont have any oil light i think and my gauge dosnt work
no lights came up when the wire was disconnected no lights came up once i connected it.
how can i fool an oil light on if i have one?
Old 11-07-2010, 10:02 PM   #5 (permalink)
CERTIFIABLE CAR NUT
Zembonez's Avatar
On most vehicles you can ground (to earth) the sending unit wire and the gauge will peg or the light will come on.
Old 11-07-2010, 10:19 PM   #6 (permalink)
just tryed that nothing happend
the wire is ground i know that
if a oil light is the one that looks like an oil can with drips i dont have it
14volts at postive and ground at the gauge
opened the gauge up theres a whole lot of wire coiled around a metal sheet which is burt out no contact. which is heated up to show your reading does. anybody know what kind of wire it its eg fuse wire or what?
i also tryed to just twist is back together nothing happend
or where to buy a whole new cluster thats the same as 87 levin oil pressure / volt meter gauge?
it looks like ill need to buy a new gauge if i buy a new gauge will i need to fit the sender that comes with the gauge or will the stock sender be sufficint?
Not stock gauge (aftermakertet gauge)brand auto gauge
Old 11-08-2010, 10:13 PM   #7 (permalink)
i dont have a light its just a gauge
would the oringal oil sender unit be sweet with a new after market gauge (that comes with its own oil sender unit) just the hassel of riping apart the front of my engine to install the new sender will be a mission
Old 11-09-2010, 04:30 PM   #8 (permalink)
bump
Old 11-10-2010, 07:21 PM   #9 (permalink)
Donald's Avatar
Gameroom cash: $201420
View Donald's Photo Gallery
The oil pressure sender is a ground.
The wire going to it should have 12v with the ignition on.
Test the sender by puting an OHM meter on it (to ground) with the engine running. (very hard to get to without scorching your hand)
Test the wire by puting a volt meter or a 12v light bulb on it, with the ignition on.
'88 Corolla, AE92 SR-5, 7A-FE swap/GT-S suspension
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
Donald is offline   Reply With Quote
Old 11-11-2010, 01:36 PM   #10 (permalink)
Rotary guy...
eage8's Avatar
Gameroom cash: $434050
View eage8's Photo Gallery
non-GTSs had lights, the GTSs had gauges. make sure you have the right oil pressure sender (they're different for the light and gauge) one looks like a mushroom and one just looks like a coolant temp sensor or something.
the wire also connects to it differently.
'81 BMW R65
