There is a repair kit that you can get at the auto parts stores.
In the kit there is a conductive paint that you apply to broken/damaged areas of the strips (lines).
Sometimes the broken areas are very obvious, but sometimes you need to look at the strips with a magnifying glass to see where it is broken.
Those strips are usually damaged by objects resting against the glass, or when you try to remove tint film.
'88 Corolla, AE92 SR-5, 7A-FE swap/GT-S suspension
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
