1985 Toyota Corolla problem - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla Forum > Older Generations (1969-1987)
Older Generations (1969-1987) Specific discussion of the AE86, along with generations 1 through 5.
Old 12-14-2010, 07:07 PM   #1 (permalink)
View thedark_master's Photo Gallery
So I am having problems turning on the car when it has been working for a while and is warmed up. In the morning when the car is cold and hasn't been started, it starts up fine with no problem. After it warms up in 10-15 minutes while I am driving it, when I stop at a stop light it shuts off and its really hard to start it up again. Is there any suggestions?
thedark_master is offline   Reply With Quote
Old 12-17-2010, 05:58 PM   #2 (permalink)
Gameroom cash: $816401
View zythr's Photo Gallery
Is it fuel injected or carburetor?
zythr is online now   Reply With Quote
Old 12-17-2010, 06:06 PM   #3 (permalink)
carburetor
Old 12-17-2010, 07:52 PM   #4 (permalink)
Donald's Avatar
Gameroom cash: $201420
View Donald's Photo Gallery
Try holding the gas pedal to the floor when trying to start.
If it starts easier that way, your carb is probably flooding because the float level is too high, or the auxillary accellerator pump diaphram is cracked.
'88 Corolla, AE92 SR-5, 7A-FE swap/GT-S suspension
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
Donald is offline   Reply With Quote
Old 12-17-2010, 08:18 PM   #5 (permalink)
thanks for the advice Donald, I will check it out and see if thats the problem
Old 12-18-2010, 03:02 PM   #6 (permalink)
Donald's Avatar
No problem.
Good luck.
