mpg?? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla Forum > Older Generations (1969-1987)
Older Generations (1969-1987) Specific discussion of the AE86, along with generations 1 through 5.
Old 12-24-2010, 10:59 PM   #1 (permalink)
View drzen99's Photo Gallery
mpg??
How many mpg do your Corollas get? I have an 86 4dr Hatchback.not fuel injected, 1.6L,with a 5 speed....I`ve only driven 200 miles so far...the 1st 100 I got 20 mpg and then I tuned it,changed all filters,plugs,wires,cap,rotar and oil and got 24 mpg??Is this normal or should I be getting more?
drzen99 is offline   Reply With Quote
Old 01-02-2011, 02:59 PM   #2 (permalink)
Donald's Avatar
Gameroom cash: $201420
View Donald's Photo Gallery
That sounds fair. How many miles on the engine?
Your driving style, road conditions (hilly / traffic / highway), tire pressures, tire size, stuff in your trunk, passengers, running the A/C, type of gasoline, all can affect your mileage.
You will get your best mileage with the original size tires maintained at the corrtect pressures, (sometimes higer than recommended by manufacturer) if you are doing mostly highway driving at about 55 MPH, by yourself with nothing but the spare tire in the trunk.
Ethanol blend gasolines will sometimes lower your milage. Don't use high octane either, unless your engine is knocking or pinging. It has lower BTUs than low octane, so produces less energy.
I am getting 28-29 mpg, with my '89 GT-S, with a '93 1.8 (rebuilt) engine swap, with much wider than standard tires, donig a mix of city and highway (mostly highway) driving, usually doing 10 mph above the posted speed limit.
'88 Corolla, AE92 SR-5, 7A-FE swap/GT-S suspension
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
Donald is offline   Reply With Quote
