1985 Corolla AE-82 fuel problem - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla Forum > Older Generations (1969-1987)
Older Generations (1969-1987) Specific discussion of the AE86, along with generations 1 through 5.
Old 01-07-2011, 02:07 AM   #1 (permalink)
View gargs's Photo Gallery
Hi All, i have 1985 AE-82 with a 4A-C engine that wont start. it just lost all accelaration at 60mph and then just shut down as i slowed. i tried replacing the fuel pump as when i took the line off and tried to start it no fuel was flowing. But i still have the same problem. it seems to have no fuel coming up at all. is there another pump or other unit inside the fuel tank which may be the problem? Any help or advice will be appreciated. Thanks.
gargs is offline   Reply With Quote
Old 01-07-2011, 03:36 AM   #2 (permalink)
verlaryder's Avatar
View verlaryder's Photo Gallery
Did you replace the fuel pump or not? On a very old (1973) Toyota I once found a fuel flow problem was caused by a kinked fuel hose that was attached to the gas tank.
verlaryder is offline   Reply With Quote
Old 01-07-2011, 04:32 AM   #3 (permalink)
Yes i did replace the fuel pump and filter as well. But i have not had a look at any part of the line back to fuel tank. Thanks for the tip.
