oil problems - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla Forum > Older Generations (1969-1987)
Older Generations (1969-1987) Specific discussion of the AE86, along with generations 1 through 5.
Old 04-07-2011, 04:38 PM   #1 (permalink)
littledm's Avatar
View littledm's Photo Gallery
2nd Generation oil problems
I have a 1977 toyota corolla with the 2t-c. Ever since i got it the oil pressure is extremely low at idle.
Im currently running 10w30 in it. when it warms up the most pressure i get out of it is 30ish psi, and thats when im running down the highway at 3500 rpm.
Does this sound like i need a new pump or just need to run strait 30 wieght oil. Also is this the front mount oil pump or internal mount. Ive seen pictures of both.
Thank you for your help.
littledm is offline   Reply With Quote
Old 04-09-2011, 02:17 AM   #2 (permalink)
TE-72_Junkie's Avatar
View TE-72_Junkie's Photo Gallery
jump on www.3tcgarage.com you might get a better answer on there
TE-72_Junkie is offline   Reply With Quote
Old 04-11-2011, 04:54 PM   #3 (permalink)
littledm's Avatar
2nd Generation update
Switched to strait 30wt and still low pressure. Looks like its time for a pump.
Is this as easy as it sounds, drop cross member, pull pan after draining, pull pump. install is reverse of removal.
Old 04-12-2011, 01:34 AM   #4 (permalink)
verlaryder's Avatar
View verlaryder's Photo Gallery
Low pressure COMPARED TO WHAT?
4 psi is NORMAL at idle. 30 -35 psi or so is normal at speed.
verlaryder is offline   Reply With Quote
