what i chose over the ft-86 - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla Forum > Older Generations (1969-1987)
Older Generations (1969-1987) Specific discussion of the AE86, along with generations 1 through 5.
Old 04-09-2011, 10:28 PM   #1 (permalink)
View aslsmm's Photo Gallery
thats right. this was 500 bucks. here are more pics
now the question is, what am going to put in it? what motor should i put in this guys? these are my top 4 choices
aluminum LS1
4AGE 20V
13b rotary
240 sx motor (silvia)
this is going to be my dailydriver/drift/preferably fast sleeper car. opinions welcome.
aslsmm is offline   Reply With Quote
Old 04-09-2011, 10:31 PM   #2 (permalink)
oh i forgot to mention, my wife gave me permission to get an ft-86 next year but toyota is going back and forth on the design and wether or not it will be a scion and blah blah blah, i figured this would be a much better and funner choice.
Old 04-10-2011, 02:18 AM   #3 (permalink)
5spd FTW!
ariel_86's Avatar
View ariel_86's Photo Gallery
more fun, not "funner"
I don't know if an LSX motor will fit in an AE86, but even if it does without modifications (and I'm not saying it will), You'll need to do some custom fabrication to fit a transmission in there. And the T56 (the 6-speeds people love to use) is more expensive than the LSX.
You'll need a stock Toyota T50 transmission and driveshaft to run a 20V, along with wiring. That swap has been done to death, so you should find plenty of info about it.
I'm sure mount kits exist for a 13B swap, I just haven't seen them sold. Expect some fabrication anyway.
Both the KA24(D)E and the SR20DET require modifying the hole the shifter comes through b/c those transmissions are longer than the T-50s. Mount kits are sold for the SR and you should be able to adapt that to a KA if you try.
Both the LSX, 13B, KA/SR swap will require a different, stronger rear end and custom driveshaft. A GTS rear can't handle the torque of those other motors (well, maybe a N/A 13B, but definitely not a turbo'd rotary). An SR5 rear can have trouble with just a stock 20V.
You might also consider an F20/22 swap from a Honda S2000.
FWIW, I've heard that the FT-86 will be badged and sold as the Scion FTS in the states starting sometime in 2012.
Physics for your head!!
2000 Camry XLE 5-Spd
1985 Corolla GTS Coupe
ariel_86 is online now   Reply With Quote
Old 04-10-2011, 02:25 AM   #4 (permalink)
yeah i knew that and that was dashing my dreams to bits. i knew i was going to have to do work on the rear end for the motor swap, im just not sure exactly how far i wanna take this project.
Old 04-10-2011, 02:32 AM   #5 (permalink)
5spd FTW!
ariel_86's Avatar
Make some decisions, come up with a plan, come up with a budget. Jumping headfirst into a Corolla without doing some research leads to hacked up cars, unfinished projects, wasted money, and missing out on a chassis and culture that can teach a lot.
Patience and research are key to a successful Corolla build. Don't expect things to come quick or cheap during your first build (unless you can do a lot of fabrication/work on your own. That can help offset some costs).
Make sure you know what you want to accomplish with the car before you start cutting wires or cutting and welding the body, because any mistake you make will make it more difficult to fix or get rid of if you get tired of it.
Best of luck to you.
Old 04-10-2011, 04:39 AM   #6 (permalink)
thanks. PSI performace in portland is going to help me with the build. luckily i have a friend over there and it allows me an aboundance of knowlege.
i am going to use a 3sgte beams motor. it fits way easier than any of the other motors i was originally thinking and they put out some awesome power. they weigh close to the same and the conversion has been done several times by PSI so they will be able to pull me out of the swamp if i get my self stuck.
Old 04-10-2011, 03:46 PM   #7 (permalink)
5spd FTW!
ariel_86's Avatar
Awesome, I'm glad you've got something figured out. I hope it turn out well and you enjoy it! Keep us updated on the progress and any issues you run into.
Old 04-16-2011, 08:22 PM   #8 (permalink)
Donald's Avatar
Gameroom cash: $201420
View Donald's Photo Gallery
Lots of photos on this build please.
'88 Corolla, AE92 SR-5, 7A-FE swap/GT-S suspension
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
Donald is offline   Reply With Quote
Old 04-16-2011, 11:32 PM   #9 (permalink)
will do. i should have a motor in a month or two. more pics will come when i get setteled after my move.
Old 04-19-2011, 11:07 PM   #10 (permalink)
Wonderbread
4agetercel's Avatar
Gameroom cash: $160040
View 4agetercel's Photo Gallery
you cant really choose an AE86 over the FT86, as it has not been released yet lol.... so you in fact had no choice in the matter,
im looking forward to some progress though, im lacking much motivation in working on my 86 right now
4agetercel is offline   Reply With Quote
Old 04-20-2011, 11:46 AM   #11 (permalink)
View 4ageFTW's Photo Gallery
Please keep this as a build thread id really like to see how this beauty comes along!
4ageFTW is offline   Reply With Quote
Old 04-20-2011, 04:58 PM   #12 (permalink)
im thinking im going with the 3sge beams motor, but i have an oppourtunity to buy a vq35de long block for 600. that motor has been put in these a few times. im just not sure on what im going to do. part of me wants to keep it a 4 cyl toyota but then the other part wants to build a beast. ill keep you all updated. pics will be up next week.
Old 04-20-2011, 05:38 PM   #13 (permalink)
Donald's Avatar
Why not go all the way?
You can have a V8!
http://www.b15sentra.net/forums/showthread.php?t=131559
http://www.superstreetonline.com/fea...wap/index.html
http://www.lextreme.com/forums/showthread.php?t=4684
Old 04-21-2011, 09:56 AM   #14 (permalink)
dont get me wrong, the 1uz-fe motor is great but they dont offer a whole lot of after market mods for it. a v8 would be cool, but a v6 would be more of a comprimise in terms of power vs practical use. no sense in feeding 2 extra pistons gas when i can get more power with the vq35de.
Old 04-21-2011, 03:38 PM   #15 (permalink)
Wonderbread
4agetercel's Avatar
why would you need more than 250 hp and 260 tq in a corolla? which the aluminum V8 easily produces, youll smoke alot of cars with that and drift effortlessly
